Author Topic: Robbe Blue Star  (Read 2168 times)
Sonparc
Robbe Blue Star
« on: June 22, 2017, 12:06:16 pm »
Any Blue Star owners out there ? I was sailing mine last week and it sounded a bit noisier than usual which I think is due to lack of lubrication. I think the jet drive unit is actually a Kehrer KMB Jet 28 - can anyone confirm this please ? If so the KMB 28 instructions say the impeller shaft can be lubricated through hole A where it says there is a grease nipple which I cannot detect . I do not want to have to disassemble the drive system if I can avoid it. I will be very pleased to have  any advice and / or experienced comment.
Re: Robbe Blue Star
« Reply #1 on: June 22, 2017, 03:43:43 pm »
Can you post some photos of the drive unit?  :-)
timgarrod
    • Alvaston Pirates Model Boat Club
Re: Robbe Blue Star
« Reply #2 on: June 22, 2017, 06:43:16 pm »
mine did this. found out the one of the bearing had rusted up and worn out. replace and ran a dream again.
Sonparc
Re: Robbe Blue Star
« Reply #3 on: June 23, 2017, 07:49:13 am »
Martin a photo wouldn't show the detail. I've attached a diagram of the unit.
Sonparc
Re: Robbe Blue Star
« Reply #4 on: June 23, 2017, 08:22:23 am »
I've had to compress this photo to get it onto the site
rsm
Re: Robbe Blue Star
« Reply #5 on: June 23, 2017, 09:06:54 am »
The bit labelled 'Schmernippel' is through where you apply grease to the prop shaft.
Regards.
Roger
Sonparc
Re: Robbe Blue Star
« Reply #6 on: June 23, 2017, 03:34:32 pm »
Tim
Thanks for your reply, how did you go about it ? . Did you access the bearing by removing components from the stern end or take the motor out? I fitted a new motor in 2010 and I remember it as a very difficult job.
timgarrod
Re: Robbe Blue Star
« Reply #7 on: June 28, 2017, 09:07:05 pm »
Hi Sonparc,
I had to remove the motor (which took forever due to one of the bolts).
After removing the prop I knocked the bearing out. when putting it back together I put a tube where the small hole is on the outer casing for oiling.
I have a spare prop i think if needed.
Tim
JIM WORNER
  • Not me chief : Engines
Re: Robbe Blue Star
« Reply #8 on: June 28, 2017, 11:03:17 pm »
Just a thought, I found Kehrer very good at supplying spares ordered from their web-site.
Jim :-))
