Pages: 1 2 [3]   Go Down
Author Topic: SG&K 1920 Gentleman's Runabout MK2  (Read 12362 times)
canabus
Re: SG&K 1920 Gentleman's Runabout MK2
« Reply #50 on: September 17, 2017, 11:58:38 am »
Hi All
Sorry all, hit the wrong button.
« Reply #51 on: September 17, 2017, 05:46:23 pm »
Now that is a lovely boat. The finish is marvellous  :-))
pompebled
« Reply #52 on: September 18, 2017, 08:42:57 am »
Hi Harry,
Congrats on a successful maiden!
A small video would be nice.
With the water not scaled down, sprayrails are a must to avoid having the bowwave crawling up to the deck.
If this would occur in the 1:1 version, the people on board would get very upset (and wet)...
Do you consider adding sprayrails?
Regards, Jan.
Boaters are nice people
canabus
« Reply #53 on: September 18, 2017, 12:55:58 pm »
Hi Jan
The trouble is that spray rails were not invented in 1920, so in keeping with the original design I did not install them.
Also the boat did not have a flag pole, but, I had to add this for  the oiler for the rudder.
I have seen a post that the sides are about 1/8" below the bottom and filled in to have hidden spray rails.
Number six project is a Miss Britain 3 at 950mm.
I had to increase the size from the original plan(130%) to get room for the 35mm motor, battery, etc.
As a stepped hull the CG is very important to get the boat sitting up on the plane.
Also I have a 3648-1450 kv 1600watt brushless which requires a boat.
Canabus
pompebled
« Reply #54 on: September 18, 2017, 09:47:50 pm »
Hi Harry,
When I build a (semi) scale model of a fast boat, my prime concern is to make it run properly, so it is a nice toy to play with.
If I have to alter the design (slightly) to acheive that, I will do so.
As an example, my M.A.S. original has two engines, my model only one, as a single motor and larger prop is more effective than two smaller ones, and, as a testmodel reveilled that small props have issues on a stepped hull, the air/water mixture, drawn under the hull by the steps rendered small props partly useless to the point that the speed dropped, untill the steps had stopped working.
My 110 cm version with one prop suffers from the same issue, but the large single prop sits deep enough to work below that air watermix on the hull bottom and keeps the grip to propel the boat forward (at silly speed, I must admit, but great fun to run).
If the bow wave crawling up the sides bothers you, I'd go for the 'hidden' sprayrails you mentioned.
Regards, Jan.
canabus
« Reply #55 on: September 19, 2017, 07:52:42 am »
Hi pompebled
The bow wave does not bother me, a bit funny, but, all the other boats give it a wide berth!!!!
Canabus
malcky56
« Reply #56 on: September 30, 2018, 08:15:14 am »
 :-)) Great photographs these will help me as I start my modelling journey. Bought this set of plans and wooden starter kit with no idea how to build so here goes.
Thanks from Somerset in England
Malcky56
canabus
« Reply #57 on: September 30, 2018, 12:03:46 pm »
Hi Malcky56
As I moved the motor and ESC under the dash I got the CG forward with the battery in the engine compartment.
If I was building another one, I would skin the rear top before the bottom and install the rudder.
The 3639-1100kv motor on 3S Lipo battery gives a good turn of speed.
Canabus
Pages: 1 2 [3]   Go Up
