Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Down
Author Topic: Wasabi 900e running gear ( Fast electric )  (Read 38922 times)
Gaci4
Re: Wasabi 900e running gear ( Fast electric )
« Reply #200 on: August 21, 2017, 11:05:27 am »
I would of thought with having a dog in the back of the prop would of made them handed and CW and CCW, just the same as aeroplane props. Or am I wrong?
pompebled
« Reply #201 on: August 21, 2017, 11:24:06 am »
Silly question which way does the prop turn ?
Whatever way you make the motor run...
DD props come in CW and CCW.
Regards, Jan.
Boaters are nice people
Gaci4
martno1fan
« Reply #203 on: August 21, 2017, 12:07:39 pm »
You need a L hand prop (thats normal rotation) , R hand is counter rotating for a twin setup .
Gaci4
« Reply #204 on: August 21, 2017, 12:12:11 pm »
I knew there was a difference cheers
martno1fan
« Reply #205 on: August 21, 2017, 09:34:31 pm »
normal rotating prop  ok2
Gaci4
« Reply #206 on: August 22, 2017, 07:03:30 am »
Which profile should the spray rails be 1 or 2 ??
pompebled
« Reply #207 on: August 22, 2017, 08:24:48 am »
Hi Grant,
1) is what Martin showed in his pictures; it deflects the spray outward.
2) tucks the spray partly under the hull and may create lift you don't want (flight risk)...
Regards, Jan.
Gaci4
« Reply #208 on: August 22, 2017, 08:37:50 am »
,so I'll go with number 1, would they go right go the tip like Martin's or fall short like yours
martno1fan
« Reply #209 on: August 22, 2017, 10:34:40 am »
One is how all my spray rails are on my boats  and the boats run perfect .Ive never done spray rails as in pic 1 nor even seen any .
Id me more worried about the strakes underneath causing too much lift than the spray rails which is why i suggested not to install them untill later if needed. Or make them shorter and dont go to the transom ,stop short by around 6".You can see the angle on this old hull,not one of mine but gives you the idea,these are a tad wider than id do them but the angle is good.Do the spray rails all the way to front by leting sides hang a tad lower that way you can add filler to get the right profile and not need to glue on bits of wood .
Gaci4
« Reply #210 on: August 22, 2017, 10:40:21 am »
Cheers Martin, yes I remember from a previous post that you advised not to add any Chines until I see how it runs. I'm just on for the spray rails and just need to know if they go right to the bow of get smaller and fall short??
Gaci4
« Reply #211 on: August 22, 2017, 02:07:19 pm »
On tne flycolor esc what of the 3 black cables are what as none of the instructions tell me so I've no idea, I assume the red and black on the same side are to the battery
martno1fan
« Reply #212 on: August 22, 2017, 02:21:55 pm »
No they go right forward tapering off towards the bow
martno1fan
« Reply #213 on: August 22, 2017, 02:30:25 pm »
Black wires are to the motor doesnt matter which goes where test and see which way the motor spins if wrong change any two wires thats it done. DO NOT TEST MOTOR UNTIL ITS MOUNTED IN THE BOAT ,or you could hurt your hand,i know a friend who held one and it broke his wrist OUCH.
https://www.youtube.com/watch?v=ZZ0gH4EAcOM
Gaci4
« Reply #214 on: August 22, 2017, 03:06:05 pm »
What is the best connector to use for the amp draw I see the cables are 10sw but what connector?..?
pompebled
« Reply #215 on: August 22, 2017, 04:18:20 pm »
I'm using 4 mm goldplated, as I have that as a standard in all my boats, but for the next build with the SSS4074- 2200Kv it's going to be 5 or 6 mm goldplated all around.
Regards, Jan.
pompebled
« Reply #216 on: August 22, 2017, 04:55:27 pm »
Something like this:
https://guide.alibaba.com/shop/3-pair-of-5-5mm-gold-plated-bullet-connectors-3-male-3-female_52608235.html
I have a handful of these lying around and without the cable soldered in place you'll need pliers to get them connected and disconnected...
Regards, Jan.
Gaci4
« Reply #217 on: August 22, 2017, 05:17:09 pm »
I've got a few xt60 and about a dozen ec5 left over from other projects they'll do then put ec5 motor side and after the series connector. Just need to get some swg cable
pompebled
« Reply #218 on: August 22, 2017, 09:01:11 pm »
Hi Grant,
If your EC5 are the sort with the spring cage on them, you'll need to solder the cage onto the connector on the foot (not the tip!), making sure the cage can still flex, in order to maintain a good connection.
Reason I mention this is the fact these cages present quite a lot of resistance when left loose, particularly after some use.
The connector will get hot as a result, to the point where the solder will melt and the cable can disconnect itself (= dead boat), been there, done that, just a few weeks ago: https://www.rcgroups.com/forums/showpost.php?p=38150352&postcount=207
Fixing the cage with solder should be done after the cable has been soldered in to avoid the solder dripping into the cage, ruining the connector.
Work fast, while securing the cable in the connector (cool it with a damp cloth) and use a big soldering iron, so the heating up is quick and only at the cage.
For the work and trouble, I'd rather get 'proper' 5,5 mm connectors.
Regards, Jan.
martno1fan
« Reply #219 on: August 22, 2017, 09:39:23 pm »
Hi Grant,
Regards, Jan.
Totally agree keep it simple  :} .
Gaci4
« Reply #220 on: August 23, 2017, 06:43:53 am »
Do you mean something like these as there just the same as the ec5 one justwith out the pladtic case
https://hobbyking.com/en_us/polymax-5-5mm-gold-connectors-10-pairs-20pc.html
Gaci4
« Reply #221 on: August 23, 2017, 06:46:37 am »
These are the type I have lying around  https://hobbyking.com/en_us/new-ec5-male-5-set-per-bag.html
pompebled
« Reply #222 on: August 23, 2017, 11:25:27 am »
Hi Grant,
Doesn't the link I sent, work?
Those are the short version, a bit less bulky in tight spaces.
These are longer:
http://www.ebay.co.uk/itm/5-PAIRS-RC-CONNECTOR-5MM-GOLD-PLATED-MALE-AND-FEMALE-BULLETS-PLUGS-/221674735378
Regards, Jan.
Gaci4
« Reply #223 on: August 23, 2017, 11:39:18 am »
HI Jan, the connectors you just sent are just the same style as I have they are the solid slit type not the balloon versions.
martno1fan
« Reply #224 on: August 23, 2017, 12:50:32 pm »
Good tip for soldering them is i drill a cpl holes in some billet aluminium or steel sit the connectors in heat em up add solder and push the wires in ,job done .
Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Up
Page created in 0.113 seconds with 21 queries.
