Author Topic: Building the FV "Mady Jeanne"  (Read 155586 times)
Re: Building the FV "Mady Jeanne"
« Reply #300 on: February 26, 2018, 09:16:01 pm »
Lovely neat planks Danielle. I will have a go at cutting mine for the Armoured Cruiser in due course.
missyd
« Reply #301 on: February 27, 2018, 02:15:09 pm »
For me cutting timber ist just fun! I could do that as a living!!!
Tody I rechecked the symetry of the hull .... not perfect but for me its alright. The Cornelia Marie and the N. Loredana had bigger mistakes regading the symetry!
I wanted to have a plank to the inside of the hull so that the frames and uprights will be secured. So I did that to a short length of the hull and I was happy with the result.
First one is glued in place ....
Another one at the bow ....
And I partially sanded down one side .... just love the look of it.
Skipper is inspecting today work .... he is very happy with it.
Danielle
missyd
« Reply #302 on: March 01, 2018, 01:38:31 pm »
Fixed 2 planks to the hull yesterday ....
... and beefed up the first frame. It was to thin and glueing the planks to it too much of a hassle. Thats 9mm ply ... cuttings from the Cornelia Marie.
Today 4 planks .... glued and nailed in place in one go!!! Quick and tiring process. In a few days I will have to turn over the hull or I can't use the hammer for the nails anymore ...
Danielle
SailorGreg
« Reply #303 on: March 01, 2018, 04:35:24 pm »
Nice to see the skipper lending a hand!  Beautiful work Danielle.
Greg
Brian60
« Reply #304 on: March 01, 2018, 07:32:17 pm »
I look at the work of art that the frames are and think its a shame to cover them in planking O0 O0 Beautiful work Danielle.
« Reply #305 on: March 01, 2018, 09:54:25 pm »
Totally agree Brian. If I were to commission a scale model of the Mary Rose as she is today, I would call on Danielle or Brian B as they both do superb carpentry.
missyd
« Reply #306 on: March 06, 2018, 02:52:12 pm »
Thanks a lot my friends!!!!!  :-))
Brian B and other work much better than I do ....  ok2
The planks at the stern need to be watered and fixed to the hull for 6-12h ... here you may see how nice its bent in two driections.
Sorry for the crappy pictures today ....
The next one fixed on the hull and will be ready tomorrow ....
Danielle
missyd
« Reply #307 on: March 09, 2018, 10:31:15 am »
Time to take the hull off of its workbase .... I can put it back anytime as long as there are no planks near the keel.
Works very well my workbase .... I can't use the keel-up method .... it disturbs the 3D view and I can't get the shapes right.
A new delivery of planks has arrived .... the small profiles in the front are the rest of what I did cut off..... I will use it for other projects.
A quick sanding just to show off my work .... I used a sanding block. The hammer and a punch(?) are used to drive the nailheads into the planks. I will try to get all nailheads into the planks before I do the sanding. The nailheads wont be visible at the end. I will cover the holes with some putty.
Hull weights nearly 5kg .... massive but not really heavy!
Danielle
« Reply #308 on: March 09, 2018, 07:56:44 pm »
The quintessential essence of the hobby hoarder is useful offcuts of wood! At what point do you say you have enough and cycle through your collection rooting out poorer pieces for use as stirrers etc?
Looking good  ok2
missyd
« Reply #309 on: March 10, 2018, 04:03:50 pm »
I normally use cutoffs for the deck planks and the small ones for the inside of the wheelhouse. Maybe I start building model houses or freight cars in 1/13 scale from trench light railways in WWI (project started) ....
BTW any suggestions for a motor? I was thinking of the same Krick Max Gear 6:1 (12V, batteries 12V) I used for the N. Loredana .... maybe it is to small for a 30-40kg boat?
I will use a geared version .... with it I can go "full ahead" and the propeller 80mm turns with 3-4000rpm maximum ....
The one I used with the N. Loredana .... https://www.racingmodellbau.ch/schiffsmodellbau/antriebe-und-zubehor/max-gear-getriebemotor-6-1
It also exists in 2.5-1 version ....
Danielle
missyd
« Reply #310 on: March 12, 2018, 03:05:16 pm »
Sunday I made a net/trawldoorwinch with my Meccano my dad had as a kid .... and I had it too .... wonderful construction you can make!
The goal is to have a 100% working netwinch (incl. trawldoor winch) without the need to use my hands to let it into the water ....
The hull is just a little bit too big for my small workspace .... but I always find a solution to work on it. The N.Loredana is also in this this workspace with washmachine/dryer and my eBike.
Today only 3 planks to do to have a left/right side the same ....
Danielle
jarvo
  • Etherow model boat club
« Reply #311 on: March 13, 2018, 11:47:16 pm »
HI Danielle, as you are starting to sand the planks, save the sawdust to make a filler paste, just put a stocking over the hoover nozzle to collect the dust, then mix with PVA into a thick or thin paste, saves money and just as a bonus it matches the planks perfectly.
Mark
Tugs are for pulling
missyd
« Reply #312 on: March 14, 2018, 04:43:31 am »
Thanks a lot Mark for the suggestion with collecting the sawdust .... actually I had the same idea yesterday!
Danielle
jarvo
« Reply #313 on: March 14, 2018, 02:06:59 pm »
You see, great minds think alike
missyd
« Reply #314 on: March 14, 2018, 05:17:20 pm »
Planking at the stern is nearly done .... looks alright for me. I must say that planking is going very smoothly at the moment. Since plank #1 (on top, where the deck will be) I could add one plank after plank with ease. The curves and bends are sometimes just under the breaking point of the planks at the bow.
At the bow there are a lot planks to add.... some of them I added today.
Danielle
missyd
« Reply #315 on: March 27, 2018, 04:21:37 pm »
After one week holidays in Britanny I am back for some more work on my hull ... motivation is rather low at the moment. So I did not make pictures as they progress they would show is only 4 short planks ....  %)
Danielle
« Reply #316 on: March 27, 2018, 09:35:49 pm »
Life is one big holiday for you Danielle  %)....plenty of fishing boat hulls in Brtianny?
Tell us, have you estimated a displacement yet?.... Derek
« Reply #317 on: March 27, 2018, 09:38:06 pm »
I think your inner Danielle reckons you need a little more rest and recuperation!
missyd
« Reply #318 on: March 28, 2018, 04:00:36 am »
Displament of the hull .... the original model has a weight of 50kg..... waterline is some 50mm lower than the first plank .... I am shure it will be way over 30kg! %)
There where some nice hulls to be seen in Brittany .... northern brittany have only a few ports.
They main problem at the moment is .... I am without a job since nearly two years .... this means I am on holidays since 2 years and its getting boring and demotiviation has to be fought every day ..... I had a new job for 2 month but had to quit it just before xmas because I couldn't do my job and the person I should have worked with had never time to for me (invoicing of servicing rapports).
Danielle
missyd
« Reply #319 on: March 28, 2018, 04:48:38 pm »
Symetrical planks on the bow .... the planks are still in one line frome the bow to the stern. Never made a hull like this one .... it has a perfect shape.
Danielle
« Reply #320 on: March 28, 2018, 08:49:32 pm »
We wouldn't expect anything less Danielle! Was that boat in the picture past its best, or was the water rougher than it looked?
Mind you it doesn't seem to have a wheel house  {:-{
missyd
« Reply #321 on: March 28, 2018, 09:59:33 pm »
The hull seen in the picture is left to rot on the beach .... this is an usual thing to do if your boat is old and dying .... let it sit on a beach or in marshland where the elements will turn it back into its single elements. Tanks have been emptied and all big equipment, engine, netwinches etc removed.
I think under EU law it is forbidden but I have seen one new hull since february at the port of Paimpol.
Danielle
missyd
« Reply #322 on: April 05, 2018, 02:19:01 pm »
At work again after easter .....
First I needed more glue .... I use a lot of glue at the moment. I use only this quality for my models .... its not waterproof but everything is waterproofed with color and lacquer.
Planking is nearing its end .... maybe 2 more weeks .... can't see it anymore and my wrists are in a bad shape at the moment.
Danielle
« Reply #323 on: April 05, 2018, 09:01:25 pm »
Pace yourself Danielle and you will soon be moving onto the next exciting part of the project. Just know that you are doing great and the carpentry is fab  O0 :-))
hama
« Reply #324 on: April 05, 2018, 10:41:04 pm »
Hello Danielle!
Give yourself a pat on the back for the excellent woodwork and the 25000 views!
Watching you building a modelboat is like watching a full scale build!
All the best
Hama
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25   Go Up
