Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25   Go Down
Author Topic: Building the FV "Mady Jeanne"  (Read 155945 times)
birlinn
  • Old git in a garage
Re: Building the FV "Mady Jeanne"
« Reply #475 on: October 06, 2018, 06:33:36 pm »
I would worry the tinplate will bend far too easily.
Me? I would go for 5mm brass at your scale.
JimG
« Reply #476 on: October 06, 2018, 08:34:32 pm »
If using tinplate make sure that the edges are well sealed otherwise they will rust rapidly when wet. (tin makes steel rust faster than normal.)
Jim
Dundee Model Boat club
missyd
« Reply #477 on: October 07, 2018, 06:44:52 am »
I do not like to work with brass that much .... use it only if there is no other material suitable ...The bilge keels will not bend nor beark of nor bend.
I will seal the edges with a lot of paint ....
Actually I think, as most of you are building ships the normal way (things break off easily) , the question if the bilge keel will be strong enough amusing ....
Danielle
missyd
« Reply #478 on: October 08, 2018, 07:26:42 pm »
2nd bildge keel ready! Always wear safety glasses if working with metal and other materials ....
Danielle
missyd
« Reply #479 on: October 09, 2018, 05:57:20 pm »
Today I used my special tool to work with tinplate .... you can cut the pieces and you can fold them to 90°....Very sturdy the 90° brackets. The 2 visible brackets where made to see how it works out.
I will drill one hole in the brackets to screw it into the hull and make the corners rounder....
Danielle
« Reply #480 on: October 09, 2018, 10:37:56 pm »
I nearly bought one of those bend chop and fold tools years ago at the now defunct Axminster Power tool Expo as they had such devices on offer! I am green with envy  :} Lovely job on the keels.
I used to love watching the wood turning demos. I won several bowls made and paid a good few quid for them (Money going to Devon Air Ambulance) and gave them away as raffle prizes at a do a few weeks later. It was like pearls to swine, someone even had the cheek to ask if I had got a lovely spalted beech one at Ikea  <*<
missyd
« Reply #481 on: October 31, 2018, 03:47:25 pm »
Haven't done much the last 3 weeks ... as said before ... I lost a little bit interest in shipbuilding at the moment. I also was 10 days in France to visit the Bretagne again and a quick tour of the ports in Normandy (I did not visit any military things) and Pas de Calais. Lots of beautiful ports to visit!
So today I spent nearly 2h to finish the bilge keels. They are rather nice!!!
The usual crocodile clamps to hold everything together.
And here the sinished bilge keels. Happy to have them finished. I was not shure to get them right.
Danielle
missyd
« Reply #482 on: November 01, 2018, 04:51:58 pm »
Fixing the bilge keels to the hull. I used M2x6 hex screws.
A very nice detail even if it will not be noticed later.
Both sides finished.
The bilge keels are securely fixed with the hull. I made the test!!!
Finished with this important detail. Now I will fabricate the rudder ....
Danielle
« Reply #483 on: November 03, 2018, 12:13:25 pm »
They'll do the job, and be sturdy enough to sit her on if needed.
missyd
« Reply #484 on: January 16, 2019, 06:36:59 pm »
The bilge keels started to rust. I removed the rust by sanding the keels and a brush with some black matte paint covered everything in no time (leftover from the Cornelia Marie).
I'll finish this project in the future but I have 2 other nice projects waiting to be finished. I need some time off from shipbuilding ....  %) A) I used a Traxxas TRX4 4x4 Chassis Kit to build a RC version of my wifes Suzuki SJ410 offroader she had as her first car. It has a scale of 1/6.6 ... the kit has 4x4, RC 2 gearshifting gearbox, the 2 differentials can be locked by RC.B) I purchased from eBay in the UK a livesteam locomotive from the 60ties ... I need some TLC to get it running again. Its fired by methylated spirits. Its gauge is 3". So I have to build all the track by myself. I just bought another one from eBay from the same antiques shop on eBay. They are rather nice as the builder left them unpainted. So everything is shiny in brass, copper and steel.
Danielle
Big Ada
« Reply #485 on: January 17, 2019, 06:25:21 pm »
It is great to see you back Dannielle, I think we would like to see your New Steam Engine, will you be Posting work you are doing on it on this Forum ( we do have " Other Builds " )  O0 O0 O0.
Len.
missyd
« Reply #486 on: January 17, 2019, 07:36:13 pm »
Len, I will make a tread on "other builds" in the future ....Just one pic of the steam-loco .... I bought it because it is freelance and has character ...
And one of the Suzuki SJ410 ... very difficult to build from lousy plans and a 1/43 scale model. Actually the chassis kit is 1/10 scale .... this shows how small this Suzuki really is that I can build it in 1/6.6 scale
Danielle
missyd
« Reply #487 on: April 17, 2019, 06:29:17 pm »
Yesterday before going to bed I had the idea for my netwinch...no need to put the trawldoor on the net. Just let it slip into the water.The trick is....the net must be on the winch the wrong way. Using a third rope I start with the end of the net. May also work with twin nets...
My good old Meccano netwinch simulator was of great help!
First you let the trawldoors and part of the net into the water. I think the ship should be stopped and/or the prop protected with some device. No need that everything gets into the prop.
Looks ok ... now the net lowered more into the water and maybe e little bit of foward motion iss needed for the next step.
Extend the trawcables to the maximum length. The net is upside down....with some wight in the end it shoud be possible to accelerate a little bit and turn the net under water.
It will then look like this ....
Hauling in the net is easy. Use the net- and trawlwinch together to get the net in. Ship should be stopped or advancing slowly.
At the end everything should be on board nice and tidy....Hope it will work...I will give it a try as it will add to the fun of going to model shows to show of what can be done with a fishtrawler.I think in deeper water the net could hang vertically in the water und then will plenty of acceleration it should turn as it should be...
Danielle
« Reply #488 on: April 17, 2019, 11:23:43 pm »
I reckon that it is worth trying. One of the manufacturers produced a model boat with a daughter boat that can be controlled,
Brian 60 is also working on a ship with a daughter boat in a compartment with rollers!
Kenny (RIP) was working on a complex Bireme, And there are several gun fire simulators in service or being built, so you stand your corner for the Mayhem Fishing fleet Danielle!
Taranis
  • Balne Moor MBC
« Reply #489 on: October 21, 2019, 09:18:37 am »
Missing your posts Danielle, hope you are well and still building
ANDY
« Reply #490 on: October 21, 2019, 08:45:23 pm »
Yes, I often think of you and your excellent builds. I hope you are OK. Touch base if you can  :-)
missyd
« Reply #491 on: October 23, 2019, 08:20:40 am »
Hello all...everything allright here in Switzerland...haven't found the time and energy to start building again...my job is so demanding that I afteer work I have no energy and brainpower left to be creative in my workspace...I will (if possible) change to part-time working 80% in 2020 if my boss gives his ok. This would give me Monday off for my hobbies....
Greetings to all for you!!!
Danielle
Taranis
  • Balne Moor MBC
« Reply #492 on: October 23, 2019, 08:37:06 am »
We are glad to know you are OK  :-))
ANDY
« Reply #493 on: October 23, 2019, 09:08:32 am »
Hullo Danielle....from Australia........ %) ?.....I hosted your digital images when your IT provider hiccuped.
...... we will wait  O0 until 2020 if that is what is needed
Remember I asked your advice about your rudder chain drive........I have sort of copied but it will be visual......
So same concept but with alternate material
MikeK
  • Utter Bloody Chaos !!
« Reply #494 on: October 23, 2019, 10:48:31 am »
I second that, many pleasurable hours spent reading your latest creations
Mark T
« Reply #495 on: October 23, 2019, 04:08:29 pm »
Yep and me - good to hear your ok :)
missyd
« Reply #496 on: October 26, 2019, 09:02:45 am »
Derek...thats a brilliant solution with your chaindrive....where did you find the parts for it? I can't find such realistic looking items.
Danielle
« Reply #497 on: October 26, 2019, 09:16:15 am »
Danielle........it is from Jin at Microcosm in China....he offers different bore sizes.....the mechanical strength of the chain will not equal your stainless wire loop chain.......however the brass chain has a visual place in model engineering O0 .....Derek
http://www.microcosm-engine.com/index.php?main_page=product_info&cPath=28&products_id=316
missyd
« Reply #498 on: October 27, 2019, 04:54:59 pm »
Ok look very nice but for daily abuse when trawling the boat lake I will use my chain...  ok2
Danielle
missyd
« Reply #499 on: February 15, 2020, 06:43:53 am »
I am cleaning and tidying up my workspace. It was impossible to work in such a mess. Also a reason why I stopped building the Mady-Jeanne last year. But there is a bright light on the end of the tunnel....it will take another 2-3 weeks to get everything sorted out but I will have much more space to work. The Masy-Jeanne can be parked in the far corner and will be out of the way. I also bought a big bandsaw from Metabo....At the moment it looks even worse as I have to put all thing somewhere to get space cleared to put thig back in boxes etc.... but in the end it will ok.
Danielle
Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25   Go Up
Page created in 0.117 seconds with 21 queries.
