Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... 25   Go Down
Author Topic: Building the FV "Mady Jeanne"  (Read 156129 times)
jarvo
  • Etherow model boat club
Re: Building the FV "Mady Jeanne"
« Reply #75 on: August 30, 2017, 10:46:08 pm »
Half the world's supply of clamps. I think i have the other half!!!
Mark
Tugs are for pulling
missyd
« Reply #76 on: August 31, 2017, 05:57:04 pm »
More frames built today .... two fixed on the keel the others glued together or ready to be glued.
I used 2 plywood board 1000x400x6.5mm sofar. 24 frames (x2 each is double) 48 frames with 0.8m2 plywood is a very good result. I bought 5 boards and I might end up with 1 board left over.
Danielle
« Reply #77 on: August 31, 2017, 06:36:39 pm »
Those frames at the stern are a touch of class with the curves up to the center over the prop.
Luverly  :-)
RAAArtyGunner
« Reply #78 on: September 01, 2017, 12:26:55 am »
Shaping up to be a very solid framework  O0 O0 :-))
Would be suitable for a good bumper boat  {-) {-)
Seriously, lookin good :-)) :-))
missyd
« Reply #79 on: September 01, 2017, 07:07:30 pm »
Thanks a lot!!!!  :-)) :-)) :-))
It will be a hardcore model fishtrawler. One that you can use if the lake has very high waves ....  :}
2 Frames (2x2 frames) on a 15x40cm board ....
Looking good the last two added frames!!!
I hope I have most frames finished til end of the next week!
Danielle
« Reply #80 on: September 02, 2017, 02:35:58 pm »
That's a lovely hull shape forming Danielle.
missyd
« Reply #81 on: September 04, 2017, 05:42:49 pm »
Thanks a lot my friend!!!!  :-)) :-))
You can really see how the hull takes shape and how it may look at the end! I just love my method of building a hull.
Today I tried to find out if the bow is in the right shape. Looks OK sofar but I have to do further checks and tryouts till I will glue in the frames.
Todays work (4 frames) viewed from the inside.
Danielle
missyd
« Reply #82 on: September 05, 2017, 05:39:12 pm »
Today what else ... FRAMES - FRAMES - FRAMES .... I start to have nightmares about them ....  ok2
Any frame that does not fit 100% will be sanded down ....
I am very happy with the result sofar!
Danielle
T33cno
« Reply #83 on: September 05, 2017, 06:28:10 pm »
Wonderful work  8)
Was the Lego Technics in the background yours ?
missyd
« Reply #84 on: September 05, 2017, 07:17:45 pm »
Yes mine and my wife has also a few!
Thats a very nice excavator!!!! Never seen it before ....
Danielle
T33cno
« Reply #85 on: September 05, 2017, 07:44:18 pm »
It's what is called a MOC My Own Creation but not by me. It is built from private plans has 6 motors and LiPo batteries along with Sbrick that allows control from iPhone  :-))
That blue crawler crane I have also converted to 6 motors  8)
T33cno
« Reply #86 on: September 05, 2017, 07:47:19 pm »
missyd
« Reply #87 on: September 06, 2017, 04:39:51 pm »
I just love these DIY Lego sets you can download from the internet. Sadly the parts are way too expensive ....
The biggest frames are glued in .... only a few left to make.
To check the shape of the hull I made a cardboard "deck". Everything looks allright sofar. A few frames are not exactly aligned but they are flexible enough that I can push or pull them to get them to the right place.
I will made a plywood deck and fix it to the hull temporarly. So I can finish each frame to the exact length and fix it with a small screw. So the hull will stay in form when I add the planks. Hope it works out as planned.
Danielle
missyd
« Reply #88 on: September 08, 2017, 12:07:20 pm »
Here a picture from a fishtrawler with a wooden hull. The frames are massive and have the same spacing as I use (width of a frame).
Picture: Chantier Naval Bernard
I controll the shape of the hull all the time before I glue the frame. So you will not have nasty surpises when all the frames are glued in and he shape is wrong.
Thats the plywood "deck" I was speaking about. Each frame will be screwed to it. It will stabilize the hull till the planking is done.
Frames #38-40 are glued in. #40 will be done next week maybe even a #41&42 ....
As said before .... this week the frames will be finished.
Danielle
« Reply #89 on: September 08, 2017, 01:15:45 pm »
Great work Danielle. What timber are the real boats being built from? hard or softwood???
SailorGreg
« Reply #90 on: September 08, 2017, 01:53:23 pm »
Now that is proper model ship building.  I almost expect to see a 1:16 scale adze lying on the bench!   :-))
Greg
DavieTait
« Reply #91 on: September 08, 2017, 03:03:28 pm »
Depends on the yard , normally Iroko planks on Oak frames , sometimes Oak on Oak though
Davie Tait,
Scotland
RAAArtyGunner
« Reply #92 on: September 09, 2017, 10:54:06 am »
Yes, as you say the spacing of the frames and planking being almost equal, makes for a very strong robust joint connection, thereby "locking" it all together.
Good choice of subject.  :-)) :-)) :-))
missyd
« Reply #93 on: September 11, 2017, 07:23:53 pm »
Thanks a lot to all of you!!!!  :-)) :-))
2.8kg is the weight of the hull at this stage ....
I cut some planks 12x3mm
The stern frame is planked
Finished ....
The whole hull from above.
Danielle
jarvo
« Reply #94 on: September 11, 2017, 07:37:41 pm »
Really looking impressive now. 2.8 Kg? think you might be launching then fitting the batteries. Still a brilliant model
Mark
« Reply #95 on: September 12, 2017, 07:42:27 pm »
Amen! She a beauty already.
T33cno
« Reply #96 on: September 12, 2017, 11:06:51 pm »
Bullet proof  O0
missyd
« Reply #97 on: September 20, 2017, 04:20:57 pm »
Thanks a lot to you all!!!!!
I was out for a while with some strange cough and fever .... and then my Jeep needed some TLC to get the daylights running again. But now I am back again.
I also found a new job! After over 15 months finally a small company was interested in my work knowledge and languages (french, english, german, italian). So from mid october on I wont have that much time to build model ships as before. But working part time leaves me with monday as my day to build my model ships.
Back to model building. I noticed that the right and left side of the frames where not exactly the same length. I do not know wherre the mistake came from but I had to correct it.
Best solution was to cut down the frames on the right side. I did that with my brand new Proxxon jigsaw.
Now its fits and looks much better! The front frames will be shortened later.
The deck is on again and serves as second workplace!!!.
Danielle
hama
« Reply #98 on: September 20, 2017, 04:55:01 pm »
Love to watch your woodworking skills!
And congratulations to the new job.
Hama
jarvo
« Reply #99 on: September 20, 2017, 09:31:35 pm »
Congratulations on the new job, only part time building, you wont get so frustrated!!!!
Mark
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... 25   Go Up
