Author Topic: Filler advice please  (Read 2257 times)
ChrisF
  • What's my favourite cake!
« on: August 28, 2017, 11:03:07 am »
I've got some minor damage to one of the spray rails/strakes.
They are balsa and it looks as though some paint has been knocked off and taken a little of the balsa with it.
Obviously I need to sort this before taking it to the water. I could just touch up the paint but I really want to fill it first.
So what do you guys recommend for filling given that it needs to be easy to sand?
The damage is about 10mm long and a couple of mm deep.
Thanks, Chris
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All scratch built and to a scale of 1:12
Re: Filler advice please
« Reply #1 on: August 28, 2017, 11:15:45 am »
I use polyfilla for such small filling.
You must remember it is water soluble so prime, undercoat and topcoat.
ChrisF
« Reply #2 on: August 28, 2017, 11:37:10 am »
Thanks for the reply Bob. I've used Polyfilla around the house but have always found it a little hard to sand. Have you used it on fairly delicate parts?
nemesis
« Reply #3 on: August 28, 2017, 02:01:25 pm »
Easy Sand car body filler, excellent stuff. nemesis
ChrisF
« Reply #4 on: August 28, 2017, 07:04:51 pm »
Thanks, do you have a favoured supplier?
« Reply #5 on: August 28, 2017, 07:12:59 pm »
if its practical baking soda and a few drops of super glue holes or dents
Buccaneer
« Reply #6 on: August 28, 2017, 08:39:16 pm »
Brummer Stopping if you can get it, you may need a specialist woodworking shop rather that a DIY mega store. Water based and sands down to a really smooth finish. Available in several colours.
« Reply #7 on: August 28, 2017, 08:51:47 pm »
Halfords sell a product called Dolphin Glaze it is a 2 part stopper for fine filling and it comes in a bag and is around £13 enough to do all your filling
ChrisF
« Reply #8 on: August 28, 2017, 09:43:55 pm »
Thanks for the replies, a number of options there.
I was in Halfords today so had a look around. All my local shop had was P38.
ChrisF
« Reply #9 on: August 28, 2017, 10:00:27 pm »
The Brummer sounded interesting so Googled it and Amazon have it.
Green Label is their exterior version (Yellow for interior use) and a small tin is £6.85 so not too expensive.
It's a one part filler which is better for small amounts and available in a range of wood colours and white which is what I've ordered.
Thanks, Chris
« Reply #10 on: August 29, 2017, 07:41:53 am »
Chris,
The pollyfiller I have is fairly fine when sanded.
If you want it harder I rub down to what I want then apply a few drops of superglue.
I still prime undercoat and topcoat after.
ChrisF
« Reply #11 on: August 29, 2017, 02:04:38 pm »
Thanks for the tips Bob.
Chris
Brian60
« Reply #12 on: August 29, 2017, 07:20:57 pm »
You can now get fillers for exterior use that are superfine, even better you slap it into the gap, and then smooth it off with a wet finger or spatula. Check out decoraters filler. This is not to be confused with the wide range of silicone fillers available.
ChrisF
« Reply #13 on: August 30, 2017, 12:55:58 pm »
Brummer should be arriving today so hopefully that will do the job.
Obviously it will still need painting but in the description it says that it is resistant to sea water. I won't be testing that claim out but it's a good sign.
Page created in 0.111 seconds with 21 queries.
