I don't know whether this is an ESC or a radio matter, so here goes.
I'm finishing a small Vic Smeed runabout for next Mayhem. It's powered by 2 basic jet drives and 2000Kv brushless motors.
I purchased 2 basic ESC's from Hobbyking, installed them and powered them up with a single battery with the receiver wires connected to the throttle on the Rx. via a Y-lead and yes, I did remove one of the red wires after going through the set up individually.
Radio was a basic 2.4 set.
Started once and then refused to co-operate.
The channel was live when tested with a servo.
I thought, OK, they're faulty or burnt out or sommat, so fitted 2 different ESC's from fleabay.
Same result.
Idiot, shouldn't have bought cheap.
However, I then changed the Rx to a 40Mhz Futaba and used my old and trusted setup.
Bingo - All worked perfectly for both sets of ESC's both on Lipo and NiMh
Am I doing something wrong?
Tony
