Author Topic: batteries  (Read 2546 times)
Les Davis
  • old badger
batteries
« on: September 23, 2017, 09:05:56 pm »
When using a 12v battery can you use it on its side or not
jarvo
  • Etherow model boat club
Re: batteries
« Reply #2 on: September 23, 2017, 09:29:37 pm »
Hi Les, one thing to think about when laying down batteries, they are heavier at one end than the other, so could unbalance your hull. (guess how i found out!!!) mine capsized in the bath!!! If possible place the batteries, bow to stern, not side to side
Mark
Tugs are for pulling
CGAux26
Re: batteries
« Reply #3 on: September 23, 2017, 09:59:55 pm »
Following up on what Jarvo said.  I have SLA batteries mounted on their sides and others flat down in my boats. The ones laying flat I found the center of gravity by placing the battery in its in-th-boat position on a small dowel on the bench top.  Roll the battery back and forth until it balances and mark that spot.  I use blue tape with a pen mark.
And GDSOB to these tiny file size limits.
T33cno
Re: batteries
« Reply #4 on: September 23, 2017, 10:03:03 pm »
Or build a big tug they’re not too fussy on weight  :-))
CGAux26
Re: batteries
« Reply #5 on: September 23, 2017, 10:33:07 pm »
But my back is fussy about that much weight.   :-)
Bet you can run all day on one charge?
T33cno
Re: batteries
« Reply #6 on: September 23, 2017, 10:39:14 pm »
Likely yes at scale speed or a couple of hours at full bore
smudger1309
  • Colwyn Bay M.B.C
Re: batteries
« Reply #7 on: September 24, 2017, 01:23:43 am »
i use nihms and lipos,  mainly Lipos as i finf they quicker to charge and hold charge better,  i kinda stop using lead acid gave my 12 volts away away with the tyne,  only got 3 pairs of 6 volts now for my Arun lifeboat in future prob change that to lipo
andyquirot
Re: batteries
« Reply #8 on: September 24, 2017, 07:35:03 pm »
Del Boy
  • Model Boat Mayhem really helps me out!
Re: batteries
« Reply #9 on: October 10, 2017, 09:54:26 pm »
Hi Les lots of good advice there. I am at an earlier stage than you and just about to select my battery. Did you go for a single or maybe two? What did you select Ah wise in the end? In my case I think two might be better as I can probably juggle them around better in the hull once the decks are in place but cannot decide on the appropriate current rating. What did you end up doing? Thanks. Derek
canabus
Re: batteries
« Reply #10 on: October 11, 2017, 09:16:53 am »
Hi Del Boy
I you use Lipo's you get more power and a number of sizes.
The Hobbyking Turnigy and Compact Zippy from 75 x 33 x 19 to 158 x 45 x 40mm.
More juggle room!!!!
Canabus
roycv
Re: batteries
« Reply #11 on: October 11, 2017, 11:26:51 am »
Hi all, I watched a documentary about advanced batteries and the last piece was about a guy who had made a water based electrolyte.  It was shown with the battery powering some lights and the battery was being stabbed all the way through repeatedly with a screwdriver at least 10 times with the lights still on etc.  He said it just can't catch fire.
Hope we shall see some of these batteries developed for our use.
regards Roy
Subculture
    • Dive-in to Model submarines
Re: batteries
« Reply #12 on: October 11, 2017, 08:39:00 pm »
I treat my packs with a bit more respect.
Del Boy
Re: batteries
« Reply #13 on: October 11, 2017, 08:59:05 pm »
Thanks Canabus I will check them out and let you know. I need to rebuild my own thread Al Khubar in Beginners with new picture source rather than hog Les's
