Just been given a Go Anywhere RC car to fix for next door neighbours kids
but the battery is weird and I am not sure how to charge it - as you can see
it claims to be an 11.1V Lithium-Ion battery but there is no balance cable fitted.
The battery works through two small brass pins, one of which is visible at the
extreme right hand side (the other pin is on the back face in a matching position)
there are + and - markings on the underside.
My Imax B6AC V2 charger will not look at it in either of the Lithium settings
without a balance cable being plugged in.
To add to that, there is a strange error, My charger shows a 3S LiPo as 11.1V
and a 3S Lithium Ion as 10.8V !
Dimensions : Width 75mm approx, Depth 83mm approx, Thickness 22mm approx
Where do I go from here ?
Richard
