Jim....a GOOGLE search on Kingdon Boilers offers a good number of images of builds......The British Martin Baylis Eng offers them, MacSteam just before closure made a number for sale....Nigel from Pendle Boilers would also be a starting point....[although these are boiler builders & sales people...not for plans]
From my limited understanding, the actual Kingdon boiler construction differed from horizontal water cross tubes to vertical heat tubes?...which would have suited coal burning.....again I am unsure if this carried over to model construction of Kingdon
look a like boilers.....having said this, they are certainly very visually appealing for a model build open launch
https://www.google.com.au/search?q=Kingdon++marine+boiler&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiXkeXv8_DWAhUHvLwKHdlOCBkQsAQIJwOur member
KBIO from France is part way with a build and using a Kingdon model boiler...... Another member here,
Bernhard BB has a beautiful open launch + Kingdon build on Youtube.......did your question in Model Engineering offer any results?
Would be interested to hear how you progress........... Derek
PS....following is from a 2015 E-Bay auction...........
This auction includes the following items:
•Absolutely brand new, never fired, 2015 Maccsteam Kingdon boiler with burner
•Maccsteam Large Kingdon boiler Operating Instructions Sheet
•Maccsteam Large Kingdon boiler Original Invoice #1694 (dated 22 January 2015)
•Maccsteam boiler test certificate complete with inscriptions as follows:
• Boiler type: Large Kingdon 5" and 4" diameter /6" high
• Boiler serial number: 090115
• Boiler capacity: 960ml
• Construction: All copper & silver soldered throughout
Number of cross tubes: 6 (six) • Working pressure: 80 psi
• Tested hydraulically to: 160 lbs/psi
• Hydraulic test date: 21 January 2015
• Tested guaranteed by: MACCSTEAM LIMITED (signed - Mike C. Abbott)
