Mess Deck: General Section > Tugs and Towing
Zwarte Zee
Chast8:
Any in build photos of Billing Zwarte Zee.
Instructions pretty vague and would appreciate a few tips.
Chas [fairly new builder]
chas:
Hi Chas, if you don't get a reply about the zwarte zee, have a look at the build log of the Billings nordkap in the working boats section. most of the general methods are identical. It's a straight forward build when you have done this method before, but can be a challenge the first time. good luck, and ask about anything that isn't clear.
Chas (another one)
roycv:
Hi Chas, are you building the plastic hull or the earlier wood hull? Hope you have the fittings kit as well, there is so much in it.
Make sure you know what you want inside the boat, motor RC etc. as some of the deck will cover parts you want to get at. If it is the wood version you should think about operating and access to the rudder.
regards Roy
Jherek:
Hi Chas, I had a thread on the forum with pictures, but they were on photobucket
Have a look at my album on Flickr
https://flic.kr/s/aHsm4VedGN
Chast8:
Hi Jherek
Thanks for the link to your build photos. I have the hull completed with a bit of help from the forum and I am sure some of your photos will help to make the instructions not quite so vague for the rest of the build. Good work by the way.
Cheers Chas :
Navigation
[0] Message Index
[#] Next page
Go to full version
