Model Boat Mayhem - Forum
Author Topic: New Springer........  (Read 1868 times)
bfgstew
  • Comfortably Numb
« on: November 12, 2017, 12:55:13 PM »
Well I have  cracked on with my new springer, not bothered with pics from the start as it is a very standard build.......until now.
I am not going to tell you what it will end up being or anything else, as it is top secret, plus it may not work. Don't worry though, as soon as I can update, I will.........I really hope this works and looks as good when it is finished as it does in my head.
Trying: The first step towards failure - Homer J Simpson
SailorGreg
Re: New Springer.........???????
« Reply #1 on: November 12, 2017, 01:08:55 PM »
Given the colour scheme, my money is on a war-springer. But armed with what, that is the question!
bfgstew
  • Comfortably Numb
« Reply #2 on: November 12, 2017, 03:13:32 PM »
It's what IT SHOULD be armed with is a clue........ :-))
Should have an update later today if my planning comes together, as building from the back of a fag packet so to speak!
« Reply #3 on: November 12, 2017, 03:29:52 PM »
Players Airman
Or
Senior Service {-)
Tug Fanatic
« Reply #4 on: November 12, 2017, 04:06:26 PM »
The coaming sure allows for a large superstructure. Watching. An aircraft carrier that should have aircraft? - well apart from our two they normally do.
bfgstew
  • Comfortably Numb
« Reply #5 on: November 12, 2017, 05:19:30 PM »
You lot are to good.
Either the big E, or Tin Lizzie...........or both?
bfgstew
  • Comfortably Numb
« Reply #6 on: November 12, 2017, 07:39:17 PM »
The flight deck built and glued together, fit edging strips next, then the 2 islands. Should be fun.......I may go for the slight oversize look, not sure yet?
jarvo
  • Etherow model boat club
« Reply #7 on: November 12, 2017, 10:48:05 PM »
Dear God, with that much power available she won't need aircraft to fly!!!!!
Mind you our new carriers haven't got any aircraft any way
Mark
Tugs are for pulling
bfgstew
  • Comfortably Numb
« Reply #8 on: November 12, 2017, 11:03:53 PM »
Wait until you see the propulsion set up...................... O0 O0 O0
bfgstew
  • Comfortably Numb
« Reply #9 on: November 13, 2017, 06:44:21 PM »
Propulsion system, going to fit my thruster pod in it, will run off 6V rather than 12V, don't it to be the first submersible aircraft carrier......... :embarrassed:
bfgstew
  • Comfortably Numb
« Reply #10 on: November 13, 2017, 10:05:43 PM »
Thruster pod in position, waiting for rubber sleeves.
Rudder arrived, now need to modify the blade.
Servo and a pair of 6V batteries next on shopping list.
Then need to find some small (3" long ish), sea harrier models which should be on this vessel.
radiojoe
  • Treat every day as your last,, one day it will be.
« Reply #11 on: November 14, 2017, 11:38:52 AM »
Love the propulsion drive idea, a bit like a Seadoo, nice one,  Revell do a 1:144 scale Harrier should be close to the size you want.  :-))
Joe
Starspider
« Reply #12 on: November 14, 2017, 11:46:16 PM »
Nice drive system you'll be able to tip the harriers off the bow all I keep seeing is a Shanon doing a crash stop lol
bfgstew
  • Comfortably Numb
« Reply #13 on: November 15, 2017, 11:29:25 AM »
Ok, did first bath tub test to check for any leaks, all good. Then ballasting, took 2.5kg to get to the water line, which has "xxxxx" me as I was wanting to use 2 x 6v 14ah sla batteries, trouble is these are 2.1kg each, so a total of 4.2kg.......damn.
I rather not use LiPo batteries as they need a lot of care and attention for safety reasons. Is there a better solution? Motor is a Leopard 800kv inrunner.
Look forward to suggestions.
Stewart
bfgstew
  • Comfortably Numb
« Reply #14 on: November 16, 2017, 01:48:40 PM »
Decided to use 2 x 4.5ah sla batteries instead for time being, see what run time I get off them.
radiojoe
« Reply #15 on: November 16, 2017, 02:16:56 PM »
I've got two 12 volt 1.2 ah in mine with a 540 motor it runs for hours,  ok2
Joe.
bfgstew
  • Comfortably Numb
« Reply #16 on: November 16, 2017, 02:24:10 PM »
Wow, that's good Joe.
Not sure how power hungry the brushless motor is going to be?
Gonna be fun finding out though...... :-))
bfgstew
  • Comfortably Numb
« Reply #17 on: November 18, 2017, 09:43:37 PM »
A question guys. I would like a servo that has 180 degree rotation for steering, for the life of me I cannot find one. Nothing fancy oe expensive.
Stewart
radiojoe
« Reply #18 on: November 18, 2017, 10:34:20 PM »
Hi Stewart     Hitec HS 77 BB 180 retract servo.  19.99   if it helps.
Joe.
JimG
    • Dundee Model boat Club
« Reply #19 on: November 19, 2017, 09:52:56 AM »
Joe.
Better check if it is a proportional servo first. Retract servos tend to be two position only, either fully left or fully right and don't center.
Jim
Dundee Model Boat club
http://www.modelboating.co.uk
radiojoe
« Reply #20 on: November 19, 2017, 11:08:13 AM »
Yeah the 77 is proportional the 75 is what's commonly known as bang bang, although as Stewart's using a rudder I was wondering why the 180 degree, anything over 45-50 degrees ether way and the rudder becomes inefficient. a standard servo would suffice, maybe Stewart has something else in mind.   :o
Joe
bfgstew
  • Comfortably Numb
« Reply #21 on: November 19, 2017, 03:55:56 PM »
Thanks for pointing out my error. Yes 180 is going to be wrong......DOH.
Just that a standard 60 degree servo is not going to give a great turning circle.......maybe 90 degree? Sorrg for being a dumb ass!
Tug Fanatic
« Reply #22 on: November 19, 2017, 04:03:11 PM »
I am not sure how your steering is going to be connected but the relative length of the arms on the servo & rudder will change the amount of rudder deflection available. I have never found maximum rudder angle to be a problem as there comes a point where the rudder really doesn't help by turning any more.
« Reply #23 on: November 19, 2017, 04:08:42 PM »
My Springer turns in it's own length.
Steerable Kort nozzle works for me
and my first had a fish tail rudder
which was almost as good.
radiojoe
« Reply #24 on: November 19, 2017, 04:21:55 PM »
I agree with Ned, the fish tail rudder works really well, my first Spinger practically turns on it's axis with the rudder aprox 45 degrees.
Joe
