Author Topic: Gluing ABS  (Read 3394 times)
BOF
Gluing ABS
« on: November 20, 2017, 08:16:12 pm »
I have seen an ABS hull that is begging to be completed, but I do not have the know how to even start the process of joining the Hull and preformed Upper works, as I have been told that none of my regular glues will work.
Anyone got any suggestions please?
BOF  ;)
Re: Gluing ABS
« Reply #1 on: November 20, 2017, 08:26:11 pm »
My first reaction was to say Epoxy, but on reflection there might be more to it than suggested.
I would recommend viewing our  'Gluing section' as all sorts of glue is mentioned for the different surfaces.    :-))
ken
Guy Bagley
Re: Gluing ABS
« Reply #2 on: November 20, 2017, 08:28:02 pm »
are the upperworks abs too ?
RMH
Re: Gluing ABS
« Reply #3 on: November 20, 2017, 09:02:33 pm »
Epoxy doesn't stick that well to ABS. The best glue I have found is UHU Acrylit, not cheap but does a really good job
Stan
Re: Gluing ABS
« Reply #4 on: November 20, 2017, 09:24:15 pm »
HI Bof pm sent  look forward to hearing from you.
Stan.
grendel
Re: Gluing ABS
« Reply #5 on: November 21, 2017, 06:26:54 am »
I use acetone for abs, I also use it to form a slurry that is spread very thinly on the glass bed of my printer to help the parts stick. you can buy small bottles at most chemists, or by the liter online. for joining parts just spread a thin coat on each part with a brush , then press together. acetone is also used to smooth abs parts from the printer, parts are put into an enclosed space with acetone fumes, for as long as it takes to slightly melt the surface, then removed and allowed to set again.
note test on an inconspicuous area or piece of scrap first
tica
    • Skalamodelskibe
Re: Gluing ABS
« Reply #6 on: November 21, 2017, 06:58:38 am »
I use this product for small joints  https://www.deluxematerials.co.uk/en/rc-modelling/116-plastic-magic-5060243901545.html
It can also be mixed with cut off's of the material that you will glue and then used as a thick glue. the same can be done with acetone but it is more smelly.
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
rickles23
    • Royal Navy Commandos
Re: Gluing ABS
« Reply #7 on: November 21, 2017, 07:17:24 am »
here in Oz I had a lot of trouble finding a proper glue.
Then I got hold of a guy from IPS Corporation and he just said Number 16 is what you want.
he stated that it would glue any plastic to plastic providing it was left overnight to cure
I cannot fault the glue at all. It is similar to the Airfix tube of glue but it has a stronger smell.
Do not use it indoors or the other residents will complain.
T33cno
Re: Gluing ABS
« Reply #8 on: November 21, 2017, 08:27:31 am »
Deluxe Materials FUSION will join ABS
T33cno
Re: Gluing ABS
« Reply #9 on: November 21, 2017, 08:35:31 am »
I must say that looks a superb product used with the pinflow applicator. :-))
Fusion is probably overkill but great when dissimilar materials
Re: Gluing ABS
« Reply #10 on: November 21, 2017, 02:06:49 pm »
Is Stabilit Express still around?
RMH
Re: Gluing ABS
« Reply #11 on: November 21, 2017, 04:15:09 pm »
Acrylit is virtually the same as Stabilit
BOF
Re: Gluing ABS
« Reply #12 on: November 21, 2017, 05:22:23 pm »
Yes I'm sorry to say. Means they may be easier to glue up (if I find out how) but the down side is they are quite fragile.
BOF  ;)
JimG
Re: Gluing ABS
« Reply #13 on: November 21, 2017, 05:36:26 pm »
For gluing ABS especially to itself go to your nearest plumbers merchant and buy the glue for ABS pipe joints.
Jim
Dundee Model Boat club
bj
Re: Gluing ABS
« Reply #14 on: November 21, 2017, 05:50:46 pm »
Try StixAll (300ml or so cartridge) for about £5-50 from ToolStation - available in clear, white and black. Similar product also available from Wickes.
Sticks almost anything to everything.
Re: Gluing ABS
« Reply #15 on: November 21, 2017, 09:55:52 pm »
StixAll  & StickslikeSh*T are good and very powerful but difficult to manage in small joints
BOF
Re: Gluing ABS
« Reply #16 on: November 21, 2017, 10:32:09 pm »
After all the help here it seems almost churlish to say I cant use it. I have belatedly realised that if I permanently glue the upper works to the hull there isnt a way into the thing, so it seems I will have to bolt them together through a rubber gasket or somesuch if I want to have any sort of maintenance access.
Sorry, but thanks the efforts folks.
BOF  ;)
Re: Gluing ABS
« Reply #17 on: November 22, 2017, 10:11:20 am »
What model are you building BOF?
BOF
Re: Gluing ABS
« Reply #18 on: November 23, 2017, 10:33:54 pm »
It's similar in shape to an Anatec Bait boat.
BOF  ;)
BOF
Re: Gluing ABS
« Reply #19 on: November 23, 2017, 10:44:24 pm »
I fear that "Her Indoors" would have my guts for garters if I stank up her home, so thanks for the warning.
BOF   ;)
BOF
Re: Gluing ABS
« Reply #20 on: November 24, 2017, 01:06:56 am »
This is the shape of the Anatec boat :-
http://www.picturetrail.com/sfx/album/view/24790405
BOF  ;)
