Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Group Build? Revell's 1:144 Flower Class Corvette.  (Read 78024 times)
« on: November 27, 2017, 12:39:39 pm »
Afternoon All!
Anyone built the smaller Revell HMCS Snowberry Flower Class Corvette 1:144 ?
Revell 05132 (2016) -
https://www.revell.de/en/products/model-building/ships/naval-ships/id/05132.html
TailUK
Re: Revell Snowberry Flower - Mini Corvette 1:144
« Reply #1 on: November 27, 2017, 01:56:50 pm »
From everything I've seen or heard about the 144th scale Corvette it's a real peach.  It's not a scale down of the 1/72nd one but a new kit in all respects.  Reports are that the detail and fit of parts is very good.  It certainly looks the part if it's put together right.  On the downside there are no crew figures but they may well appear as a separate set.
A company called "Munich Kit" has produced a set of 6 resin crew figures which also look good.
Allnightin
« Reply #2 on: November 27, 2017, 04:22:33 pm »
See May Model Boats for my article on converting it to RC.  The fit of the quarterdeck was so good I could just clip it in allowing easy access if a problem develops with the steering.
It certainly improves on the Matchbox 1/72 one in most areas although the railings are too heavy and need replacing by photo etch if building for static display.  501 parts will keep most people busy for a while!
Revell have just announced a different version - HMS Buttercup - which will presumably add minesweeping parts.
TailUK
« Reply #3 on: November 27, 2017, 05:32:55 pm »
Replacing Revell railings is a given I think (they still use that damnable practice of plastic stanchions and thread on some of their recent kits) The corvette railing are moulded but look a bit bulky.  I think there's already a PE set available.
« Reply #4 on: December 01, 2017, 12:44:43 am »
I bought the mag but can't find the article?!   :((
TailUK
« Reply #5 on: December 01, 2017, 08:08:20 am »
I had a look and couldn't find the article either.  There was an article on converting plastic kits, is that the one?
exvtop
« Reply #6 on: December 01, 2017, 08:48:22 am »
July 2017 page 46
« Reply #7 on: December 01, 2017, 09:41:03 am »
Klunk
« Reply #8 on: December 01, 2017, 11:35:03 am »
Group build???????
full time penguin
Allnightin
« Reply #9 on: December 01, 2017, 11:36:39 am »
Very sorry about that - lesson learnt, don't rely on memory
I did the micro ESC article in May which was very successful in the 1/144th corvettte
TailUK
« Reply #11 on: December 01, 2017, 12:19:24 pm »
Everyone has to apply for a pennant number so we don't all build the same ship!
« Reply #12 on: December 01, 2017, 12:39:48 pm »
OK TailUK, your Fleet Commander!   :-))
TailUK
« Reply #13 on: December 01, 2017, 12:55:57 pm »
Martin, I accept!
As you raised the thread, Martin, You get K166 HMS Snowberry. Next will be Klunk who gets, if he chooses to accept, USS Saucy (the other kit option.)
The aim will be to achieve a running, finished model by next year's show at Warwick where, hopefully, we will attempt to sail as many 1/144th scale Flower Class corvettes as possible.
Now there will be a limit on the amount of modification of the basic kit. Handrails and basic photo- etch upgrades. No huge amounts of re-building using photo-etch.
Kit must be painted but weathering isn't mandatory.
« Reply #14 on: December 01, 2017, 01:32:47 pm »
Can I Have K144 - HMS Klunk ?   ok2
raflaunches
  • The Penguins are coming!!!
« Reply #15 on: December 01, 2017, 02:02:41 pm »
Just ordered one! Can I have HMS Pennywort K111? Love the look of the acoustic hammer on the bow!
Nick B
Illegitimi non carborundum!
Tug Fanatic
« Reply #16 on: December 01, 2017, 02:54:11 pm »
I have not seen the Model Boats article but it looks interesting & I have 3 questions:
1) I calculate the beam as 70mm which seems very narrow so does it have stability issue - false keels etc?
2  Is it able to cope with being in a pond where others are churning up the water or is it a calm water only model?
3)  prop & motor? I don't think that my standard car heater motor would work well in one of these!
TailUK
« Reply #17 on: December 01, 2017, 03:12:41 pm »
I think it's going to be what I call a small pond model.  At less than 500mm long it probably isn't going to cope with the turbulence of a windy day or the fast electric boys.
As regards the prop and motor perhaps we can prevail on Allnightin to reprise the component list from his article as well as the ballast he used.
TailUK
« Reply #18 on: December 01, 2017, 03:27:02 pm »
Martin - HMS Klunk, K144
Klunk -  USS Saucy, PG-65 (subject to acceptance)
raflaunches - K111, HMS Pennywort
TailUK
« Reply #19 on: December 01, 2017, 03:33:22 pm »
On fleabay right now at 27 quid.
https://www.ebay.co.uk/itm/391472895799
Klunk
« Reply #20 on: December 01, 2017, 04:09:27 pm »
Yes martin
full time penguin
Allnightin
« Reply #21 on: December 01, 2017, 04:31:46 pm »
2) Is it able to cope with being in a pond where others are churning up the water or is it a calm water only model?
3
There is enough margin of buoyancy if you use a Super Tech sub micro servo , a 4.8V 950 mAH NiMH, a 280 sized motor and the ESC taken from a Feetech  FS90 contiuous rotation servo (as MB May 2017) plus an Orange R610 type to only require 40 grams of sheet lead for ballast to the scale waterline ad have ample stability.  I suspect you could use a 140 sized motor instead allowing a larger battery pack or a heavier speed controller but I got plenty of endurance out of the existing setup.  I used a Graupner 3 bladed 25mm diameter plastic prop which is a bit larger than the kit one.
It only weighs 370 gm and has limited freeboard but was fine during a club free sail session recently and was nippier than many!
Tug Fanatic
« Reply #22 on: December 01, 2017, 04:46:59 pm »
Thank you that helps greatly.
Klunk
« Reply #23 on: December 01, 2017, 05:12:57 pm »
Might use a deltang rx/esc all in one
http://www.deltang.co.uk/
Various types on here. Will save weight i woukd think
full time penguin
Allnightin
« Reply #24 on: December 01, 2017, 05:44:53 pm »
That was my fall back option if stability was a problem
Pages: [1] 2 3 4 5 6   Go Up
