Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: Group Build? Revell's 1:144 Flower Class Corvette.  (Read 77779 times)
tica
    • Skalamodelskibe
Re: Group Build! Revell's Flower Class Corvette.
« Reply #75 on: December 22, 2017, 03:44:09 pm »
Got a link to the railings  please Tony?
NB: Found these:
https://starling-models.co.uk/en/62-1144
The BIG Ed set and "Detail set for Revell 1/144 HMCS Snowberry Flower class corvette" arrived today and it looks great.
I'll put up some pictures later on
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
Klunk
« Reply #76 on: December 23, 2017, 04:10:57 pm »
Right. Finished work and the build continues. Have glued the hull and trial fitted the prop shaft, needed some fettling but sorted now. Dry fitted  the deck and cut the for deck at the breakwater. Will upload some pics later.
full time penguin
Klunk
« Reply #77 on: December 23, 2017, 04:12:44 pm »
Ps has anyone else started????
full time penguin
raflaunches
  • The Penguins are coming!!!
« Reply #78 on: December 23, 2017, 04:22:09 pm »
Will do when I return in January just looking up extras and additional detailing. :-))
Nick B
Illegitimi non carborundum!
Klunk
« Reply #79 on: December 23, 2017, 04:23:59 pm »
Lol i heard your getting an extension out there cos you keep putting in for leave!
full time penguin
raflaunches
« Reply #80 on: December 23, 2017, 04:42:24 pm »
Ah so it’s you who keeps rejecting my leave! %) %%
Nick B
Klunk
« Reply #81 on: December 23, 2017, 04:51:10 pm »
Im in the same position at my place.  Keeps being rejected.  I seem to pick weeks when we have special jobs on!
full time penguin
« Reply #82 on: December 23, 2017, 06:29:22 pm »
Photos Tica?   :-)
tica
    • Skalamodelskibe
« Reply #83 on: December 23, 2017, 07:02:56 pm »
Here it goes
I'll have to finish of my Pibber before I start on my build.
« Reply #84 on: December 23, 2017, 07:26:28 pm »
Nice!  How much?
tica
    • Skalamodelskibe
« Reply #85 on: December 23, 2017, 07:31:47 pm »
Nice!  How much?
£55 without P&P to Denmark
« Reply #86 on: December 23, 2017, 07:41:48 pm »
That's a good price! Cheapest I've seen, UK, is £27 EACH, on ebay!
( eBay item number: 322554245622 )
Klunk
« Reply #87 on: December 23, 2017, 07:49:23 pm »
your looking at the individual sets. Look for the biged set. Contains all 3 sets. Railings superstructure and armaments.  Starljng models 45 quid plus larsenal uograde set for 10 quid.
full time penguin
Starspider
« Reply #88 on: December 25, 2017, 12:34:08 pm »
WooHooo. swmbo got me the kit for xmas I'll sort out a which one to build in next few days.
Hope everyone else g.ot what they wanted.
Peace Colin
Klunk
« Reply #89 on: December 28, 2017, 11:27:29 am »
So far i have trimmed the new propshaft hole. Joined the hull and trimmed the deck at the breakwater. Next up will be to reinforce the hull join then fix the prop shaft in and make the rudder post . Have started to make extra deck supports around the edges
full time penguin
« Reply #90 on: January 02, 2018, 09:59:54 pm »
Starspider
« Reply #91 on: January 25, 2018, 09:20:42 am »
Hi all
Right could I ask for HMS Poppy K213 please if nobody else has asked for her. Hopeful of getting started this weekend.
TailUK
« Reply #92 on: January 25, 2018, 09:51:56 am »
Participants so far are;
Martin - HMS Klunk, K144 (actually HMS Meadowsweet)
Klunk -  USS Saucy, PG-65 (subject to acceptance)
raflaunches - K111, HMS Pennywort
tonyH -  USS Impulse PG68 Ex. HMS Begonia
TailUK - HMS Honeysuckle K27
Starspider - HMS Poppy K123
raflaunches
« Reply #93 on: January 25, 2018, 04:51:37 pm »
Hi everyone
I’ve just started my build of HMS Pennywort using the pictures of the 1/350 scale kit by Mirage and some from John Lambert. Only the hull is stuck together at the moment but I’ve removed some of the moulded detail to match the pictures. This means the removal of the Hedgehog launcher rails and the locating tabs for the Snowberry lockers forward of the bridge.
Nick B
tonyH
« Reply #94 on: January 25, 2018, 06:02:19 pm »
To be honest, I slightly lost the plot in that Impulse has become Intensity! Mainly because one of the best pics online was wrongly named %) , at least that's my excuse!
Anyhow, here's the build sofar. Main bridge structure raised and angle supports substituted for normal ones. Bridge area enlarged. Main gun tubs reconfigured. Oerlikon supports fitted. Main deckhouse shortened. Most of the portholes filled in. 4"/50 cal scratch built. Hedgehog location lifted etc.etc.etc.
Tony
Klunk
« Reply #95 on: February 11, 2018, 09:07:52 am »
Small update. Have not been able to get in my loft, but my good friend Tony Dalton managed to get my propshaft cut to size for me and made a nice motor holder plus a coupling!
I have now cleared the loft enough to carry on......but i have seen tonyh model in the flesh. I might give up!
full time penguin
tonyH
« Reply #96 on: February 11, 2018, 10:46:36 am »
Nah, don't do that!
Mine's stalled at the mo 'cos it's to cold in the shed to consider putting a coat of primer on and I'm making the normal sort of muckup when it's cold and the eyes and fingers are well out of scale with the model! >:-o
Klunk
« Reply #97 on: February 19, 2018, 05:57:17 am »
right.....have the motor and prop shaft mounted. will do pics later. i spent all last Saturday afternoon doing the rudder assembly. Ive gone with the kit one. so i cut off the fixing tab. found some brass and had another look. the rudder is not wide enough to drill a hole in, so i marked where i wanted the brass to attach to the rudder. i made a 30 degree bend in the brass and flattened the end of the 30 degree bit. i offered it up to the model ensuring the prop would not fowl. i cut and outer tube to act as the rudder post and checked all was free moving. took toge rudder off and lokked for my 1mm o rings and washers i would need to seal it all.  in the mean time, the dreaded rudder monster appeared and disappeared with my rudder.........
3 bl***y hours looking for it! not in any of the boxes i opened up for the o rings, on the desk, floor in the boat ......in short nowhere to be found! now without the original a could not even a home made version! so went and had dinner. wife asked how it was going. i told her what had happened. she then produced my rudder telling me i should be more careful.....turns out she had come up to see me and while I was getting the washers she reached over and took my rudder.amused i was not. i could have finished that section but as it stands it still is not complete as i had to go out! so not finding my wife funny at the moment......but it does beg the question.......is she behind all the disappearances of my modelling stuff? bearing in mind Ive lost 2 spektrum dx7s controllers, 1 boat and several tools.
full time penguin
RAAArtyGunner
« Reply #98 on: February 21, 2018, 07:02:09 am »
Ah the signs of true love.  %) %) I know it well, it goes with do you really need that. %% %%
Hang onto her else you will never find anything ever again. O0 O0
tonyH
« Reply #99 on: February 21, 2018, 07:23:49 pm »
Since I'm into a USN version, I'll have a fair few spare bits such as most of the armaments, mast etc. so if anyone wants them let me know.
Tony
Pages: 1 2 3 [4] 5 6   Go Up
