Matt..........if you are after small sized sheets....a Hobby Shop if you can find one will have both Styrene and ABS....
ABS has the advantages of rigidity, easy to cut and drill, end sections can heavily abraded/ring-drilled for keying into an epoxy bond against a GRP surface with a similar surface preparation
Styrene has less rigidity, Perspex is marginally more difficult to saw, sand & drill over ABS...Perspex also has very sharp edges and can shatter...many people use a tape mask on cutting lines to minimise chattered edges with Perspex
Perspex joints could be achieved in a similar process to ABS, Styrene always has the shiny greasy surface finish....and with the lower rigidity joints could be an issue
Considering the application, ABS would appear to have the advantage............last point, ABS has a relatively low melting point and will display a melted edge if used with a high pressure
or force against a belt or disk sander
