Author Topic: ABS to plywood glue?  (Read 4029 times)
drawknife
« on: December 16, 2017, 06:08:14 pm »
Hi folks,
Could anyone tell me which is the best glue for fixing Plywood to ABS plastic please. I have a little experimental project that I should like to try but cannot find anywhere that gives the definitive answer. Thanks and looking forward to seeing the replies.
Stan
Re: ABS to plywood glue?
« Reply #1 on: December 16, 2017, 06:25:01 pm »
Hi drawknife pm sent to you. I have used glues used in the building trade with no problems. Everbuild based in leeds offer a good range under the trade name of sticksall you can buy this in small tubes also.
Stan.
T33cno
« Reply #2 on: December 16, 2017, 06:28:19 pm »
Depends on the specific joint what might be suitable. Large scale or small detail?
spearfish99
« Reply #3 on: December 17, 2017, 11:12:18 am »
Having built a couple of the Graupner ABS hulled speedboats, I can say that their recommended adhesive works very well, although it is a bit pricey.   It is Stabilit Express
https://www.amazon.co.uk/Pattex-1152570-Stability-Component-Adhesive/dp/B0037Y7T4Q
« Reply #4 on: December 17, 2017, 12:27:12 pm »
 ahhh, yes.......
that goes back many moons to when I built their RAU 1X whaler, and it was supplied with a small kit of Stablit express............
My whaler took many hard knocks in its life[ including my mates ramming it regularly on the pond for what it represented, lol] and dropping it from the kitchen table onto a stone floor whilst building her, and the timber frame and ABS never parted once at any point........was a brilliant adhesive, and I would also recommend it..........next best thing to welding, so long as both surfaces are roughened with 240 paper to give a key as recommended by the manufacturer.
Dave Cook
  • Cookie
  • Keep on Rockin
« Reply #5 on: December 19, 2017, 06:43:52 am »
Hi Stan,,were can i get stixall in small tubes , i can only find it  in the large ones
Regards Dave    :-)) :-)) :-))
Stan
« Reply #6 on: December 19, 2017, 08:16:11 pm »
HI Dave please contact Everbuild on  0113 2403456 ask for customer services. Give then your location and ask who stocks the small tubes in you area. Comes in white, grey, black, and clear  while on the phone if you have any questions ask for the technical section.
Stan
bj
« Reply #7 on: December 20, 2017, 08:51:42 pm »
Large tubes (300ml) are only about £5-60 from ToolStation
Onetenor
« Reply #8 on: December 22, 2017, 02:46:19 am »
Gorilla Glue is ideal for this as it remains slightly flexible and won't crack open even if the abs flexes. Just key both surfaces with 240 grit paper first. Make a good job of this. Also E6000 industrial @£ 2.50 a tube.
tizdaz
  • Boom!
« Reply #9 on: December 28, 2017, 01:56:37 am »
I use Gorilla Superglue, i have both the liquid & gel types, cant fault it :)
My large-scale TID Build Website: http://www.tizdaz.co.uk/forum
Facebook:
Geoff
« Reply #10 on: January 04, 2018, 01:44:30 pm »
If its quite a decent surface area, regular Evostick impact adhesive works well but its important to let the fumes dissipate to avoid subsequent warping.
Geoff
morley bill 1
« Reply #11 on: January 04, 2018, 04:33:44 pm »
Graupner list UHU Acrylit for abs to wood & abs to metal in my Gruben manual  Bill...
