Author Topic: Quick tip, mixing epoxy  (Read 7114 times)
Brian60
« on: January 22, 2018, 06:17:19 pm »
Are you one of those who mix up epoxy or other glues on scraps of whatever is to hand? Perhaps a bit of wood or plastic maybe? Well this is your saviour!...
Post-It sticky pads :} Get yourself one of these pads, mix your glue, paint or whatever on the top sheet. Then peel off and dispose when finished with it. A pad lasts for ages. since I've been using this my workbench has been much clearer and less likely to stick an elbow or a valuable part to a cast off bit of scrap with glue on it.
Re: Here's a quick tip
« Reply #1 on: January 22, 2018, 06:20:37 pm »
Top Tip Hully Gully :-))
boatsdelboy2
« Reply #2 on: February 08, 2018, 04:02:23 pm »
Brill tip thanks for that
« Reply #3 on: February 08, 2018, 08:12:40 pm »
Like a wet pad but for glue! That is insired Brian. Take a bow for that one  8)
« Reply #4 on: February 09, 2018, 03:58:06 am »
Re: Here's a quick tip mixing epoxy
« Reply #5 on: February 09, 2018, 11:45:33 am »
Also,  Post-it-notes under your Hot Glue gun tip while it's on!  O0
« Reply #6 on: February 09, 2018, 11:46:27 am »
... and  while drilling holes!
T33cno
« Reply #7 on: February 09, 2018, 11:50:42 am »
AND for writing notes on  {-)
Great tips  :-))
grendel
« Reply #8 on: February 09, 2018, 12:30:04 pm »
epoxy mixing pots- a bunch of cheap disposable shot glasses from Asda about £1 for 20
« Reply #9 on: February 09, 2018, 01:27:31 pm »
5 p each >>:-(
Ask your local for the throwaways.
Quick wash costs nowt. :-))
Mark T
« Reply #10 on: February 09, 2018, 01:35:53 pm »
Also get some of those very small digital scales off of eBay they cost about £3 and you can weigh exact equal amounts whilst putting it onto the post it note
StarLocAdhesives/FiveStar
    • StarLoc FiveStar quality adhesives and glues at FMK
« Reply #11 on: February 09, 2018, 03:05:54 pm »
Reading the instructions first....
Most epoxy adhesives are mixed by volume and resin and hardener are often quite different densities so most are always measured  by volume unless you know the exact weight per ml of each or the instructions say to by equal weight its best by volume.
Laminating and coating resins are usually by weight though.
Formulators and manufacturers of quality adhesives and surface coatings for industrial , DIY & modelling sectors since 1988
See us online   www.shop-4-glue.com
on ebay https://www.ebay.co.uk/sch/gianthairyhedgehog/m.html?_nkw=&_armrs=1&_ipg=&_from=
Mark T
« Reply #12 on: February 09, 2018, 05:37:37 pm »
Well its true - everydays a school day I honestly did not know that cheers for the info!
RST
Re: Quick tip, mixing epoxy
« Reply #13 on: February 10, 2018, 04:58:02 am »
LoL I've been using post-its for mixing glue for 20 years or so but I figured it was a terrible waste these days.  The trick for me is to use whatever scrap of paper etc. and fold it over afterwards.  No need to use perfectly good post-its.  Any bit of junk mail you can't return should do.
Footski
« Reply #14 on: February 10, 2018, 07:47:54 am »
Great tips  :-))
Don't be silly. They were never designed for such use.  %%
Tug Fanatic
« Reply #15 on: February 10, 2018, 03:19:35 pm »
I just use the nozzle of the vacuum cleaner. Actively sucks it all up.
T33cno
« Reply #16 on: February 10, 2018, 04:11:36 pm »
I think it's better to catch as much as possible rather than vac it all. No matter how good the filter the smaller particles get redistributed across the room. This poses the age old question of whether to dust then vac or vac then dust  {-)  even cleaners will argue over that one  O0
I should have bought some while raiding poundland  {-)
TheLongBuild
  • Build em, and play hard..
« Reply #17 on: February 10, 2018, 04:54:27 pm »
Great tips  :-))
Don't be silly Jones!!
Be telling me next that you can actually use a smart phone to make phone calls.....
