Author Topic: Turnigy 9X failsafe  (Read 6226 times)
T33cno
Turnigy 9X failsafe
« on: February 06, 2018, 04:08:43 pm »
I've followed the instruction manual section 7.12 and set throttle to neutral but when I kill the transmitter it makes no difference.
Does anyone know something I'm missing?
Mark T
Re: Turnigy 9X failsafe
« Reply #1 on: February 06, 2018, 04:13:27 pm »
On Spektrum transmitters when you change the throttle setting you then have to rebind the receiver to reset the fail safe - maybe it’s the same?
T33cno
« Reply #2 on: February 06, 2018, 04:14:48 pm »
Good one Mark but I tried that too. I'm wondering if the manual covers an upgraded unit.
Or maybe the receiver needs an update, there's an update button on it but no instructions
kinmel
« Reply #3 on: February 06, 2018, 05:55:51 pm »
On the original model, a long Menu press did one thing and a short menu press was "save and exit".
T33cno
« Reply #4 on: February 06, 2018, 05:58:45 pm »
That's what I thought too Alan but it doesn't do anything to indicate how long. Menu press is supposed to save and Exit press leaves without saving.
Could be faulty after all I ordered a mode2 and it says this on the box but its a mode1  {-)
Fred Ellis
« Reply #5 on: February 06, 2018, 11:39:33 pm »
Link to the manual for the Turnighy 9xR  https://hobbyking.com/media/file/692301903X39217X34.
[/size][/color]
[/size]hope it help's[/color]
kinmel
« Reply #6 on: February 07, 2018, 08:17:58 am »
The  "manual"  for my Turnigy i6 transmitter says something similar and on that saving an option requires a very fast touch on the menu button.
The problem is both a long, or short press changes to the same screen afterwards.
T33cno
« Reply #7 on: February 07, 2018, 09:00:46 am »
Thanks Fred but that’s a different model
I think I will have to contact hobby king Alan
I’ve followed the manual in all permutations and no luck
kinmel
« Reply #8 on: February 07, 2018, 09:12:09 am »
Good luck with that !
See you in a couple of weeks  :}
The Old Fart
« Reply #9 on: February 07, 2018, 09:14:36 am »
When using the 9x I had to set channel 8 to strobe backwards and forwards, I then used this as a signal to Arduino, No change = no reception, move outputs to failsafe as set by arduino.
The i6x 10 channel  has easy set failsafe setting.
McGherkin
« Reply #10 on: February 07, 2018, 09:21:24 am »
I’ve not used the 9X’s stock software in a long time, but are you perhaps plugged into the elevator channel?
Also have you set it to 0% or 50%?
From what I remember of the stock software it didn’t actually tell you it had saved anything, it just did it.
https://hobbyking.com/media/file/725056143X2037269X20.pdf
T33cno
« Reply #11 on: February 07, 2018, 09:31:25 am »
Plugged into channel 3 and set to 50% but also tried 0% as I have reverse nullified.
T33cno
« Reply #12 on: February 07, 2018, 09:48:30 am »
Found an article that suggests failsafe only works in PCM mode rather than PPM. I'll try that but isn't PCM old?
JimG
« Reply #13 on: February 07, 2018, 10:56:16 am »
PCM was used for 35 and 40MHz sets and does not apply to 2.4GHz.
Jim
Dundee Model Boat club
T33cno
« Reply #14 on: February 07, 2018, 10:57:25 am »
Jim
Thanks Jim
I tried it in desperation and it went mental  {-)
T33cno
« Reply #15 on: February 10, 2018, 06:17:12 pm »
I think Hobby King are sending me another. I left a review and they picked up on it and opened a case for me.
T33cno
« Reply #16 on: February 10, 2018, 07:21:20 pm »
Confirmed Hokby King are sending a replacement and no need to send the faulty one back  :-))  let’s hope this works  :-)
T33cno
« Reply #17 on: February 10, 2018, 10:07:29 pm »
I've discovered an anomaly
I changed to a Spektrum DX6i with an Orange receiver (can't use a Spektrum receiver due to smart safe function) and throttle is connected to elevator for this.
Failsafe works but only if I switch the receiver on BEFORE connecting the batteries to the ESC's
If I have the ESC's connected and then switch the receiver on all goes "boobs" up.
The receiver is on it's own supply and the red wires on both ESC disconnected.
Anyone experienced this?
It's as though the ESC's are producing some sort of EMF that interferes with connection
RMH
« Reply #18 on: February 10, 2018, 10:42:16 pm »
If the receiver is not using a bec connection why do you need to disconnect the red wire from the esc's?
kinmel
« Reply #19 on: February 10, 2018, 10:59:31 pm »
You can only have one power supply to the receiver. So if you are using a stand alone battery, the red wire from a built in BEC must be disconnected.
If you have 2 power inputs, the white smoke escapes from the receiver and then there is nothing to push the electrickery around the circuit board. %)
T33cno
« Reply #20 on: February 10, 2018, 11:38:15 pm »
Fixed it with better equipment.
Now running Spektrum DX6 with AR6600T telemetry receiver. All works as should with same settings as the DX6i in mode 1
So I can monitor battery/ temperature/ RPM too.
I bought it for the Portgarth but didn't work out so now it has a new home  :-)
Bonus... the servos are all much smoother  :-))  11ms digital
RMH
« Reply #21 on: February 10, 2018, 11:52:50 pm »
Don't think I will ever understand this electrickery stuff
T33cno
« Reply #22 on: February 10, 2018, 11:56:09 pm »
I'm learning Guitar and I know which is easier  {-)
Page created in 0.039 seconds with 21 queries.
