April 17, 2024, 10:43:39 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Steam
steam fittings
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: steam fittings (Read 2165 times)
steam4
Shipmate
Offline
Model Boat Mayhem is Great!
manitoba canada
steam fittings
on:
February 12, 2018, 01:36:59 am »
I am a newby to steam. I am starting on my boiler a vertical design by Mr Campbell. my question is when installing the steam valve, safety valve and syphon are these items attached with a fiber washer for a seal.
steam4
DELAUNAY
Full Mayhemer
Offline
Cévennes / France
Re: steam fittings
Reply #1 on:
February 12, 2018, 06:51:07 am »
Hello Steam
Oui, une rondelle fibre ou un ruban Téflon
, a fiber washer or Teflon tape
Full Mayhemer
Offline
Dieppe, France
Re: steam fittings
Reply #2 on:
February 12, 2018, 12:09:40 pm »
I agree
Mark T
Full Mayhemer
Offline
Dudley in the Black Country
Re: steam fittings
Reply #3 on:
February 12, 2018, 02:35:54 pm »
Just another idea for you I’ve used crushable copper washers on my fittings which make lining it all up very easy except for the safety valve as this has an O ring as that’s how I fill the boiler by removing the valve
Fairmount Alpine Build
http://modelboatmayhemimages.co.uk/album/bXv
Anteo Tug Build
http://www.modelboatmayhem.co.uk/forum/index.php/topic,59708.0.html
Le Rochefort
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66046.0.html
DELAUNAY
Full Mayhemer
Offline
Cévennes / France
Re: steam fittings
Reply #4 on:
February 13, 2018, 07:19:30 am »
Hello;
Yes a good idea and those that I retained for my boilers? copper washers or aluminum under the implantations not requiring a disassembly accident, and seal or under the filling cap which is also the safety valve, which allows to control its operation with each filling.
rhavrane
Full Mayhemer
Offline
Steam passionate collector
Saint-Mandé, Val-de-Marne, France
Re: steam fittings
Reply #5 on:
February 13, 2018, 07:26:15 am »
Bonjour,
Other option, teflon tape for an accurate positioning and thread sealant like Loctite 542 for accessories that should not be disassembled usually, example water level.
Raphaël
Membre du Modele Yacht Club de Paris
http://mycparis.fr/
Membre de l'Offshore Club de Paris :
http://site-ocparis.wifeo.com/
My YouTube channel:
http://www.youtube.com/user/rhavrane
steam4
Shipmate
Offline
manitoba canada
Re: steam fittings
Reply #6 on:
February 13, 2018, 03:20:00 pm »
thank you guys. this has given me a host of options. I will probably go with Teflon tape or copper washers.
Steam 4
pendlesteam
Full Mayhemer
Offline
Burnley UK
Re: steam fittings
Reply #7 on:
February 16, 2018, 07:05:36 pm »
The best washers are tripple folded copper crush washers, the only place I can find them is Maccmodels in the UK. Do not use fibre washers - they are good but if there is a slight leak they get wet and are destroyed very quickly. I also use low strength loctite on fittings which rarely require removal. If you can machine a recess in the bush or fitting then O rings are even better.
Print
Pages: [
1
Go Up
« previous
next »
Steam
steam fittings
