Technical, Techniques, Hints, and Tips > The "Black Arts!" ( Electrics & Electronics )
electronics box / distribution
(1/1)
Klunk:
is there a piece if kit that will
a. have a 12v input
b. have a 12v 15amp output
c. 6v 1amp bec output
d. 9v 3amp output
e. 12v 5amp output???
why all this i hear you ask
a. is for the esc
b. seperate rx circuit
c. sound system
d. for a 12 to 24v convertor for a foggy unit
at present im running a p112 for the 2 x 12v pieces and 2 seperate circuits for the sound and bec. would also be good to have a 6v 3amp fir a lighting circuit
malcolmfrary:
b) and e) are simple enough from a 12 volt supply - connect direct from the battery via appropriate fuses.
c) can be taken care of by https://hobbyking.com/en_us/hxt-ubec-5-6v-output-5-5-23v-input.html?___store=en_us
https://www.amazon.co.uk/Airplane-Ubec-Aebc617-4-5a-Input/dp/B01K9GHWHI will do the job for d)
I doubt that anybody will do a single unit that has everything wanted in one go as it will be a very specific, restricted market.
No doubt Maplin have a box that will hold it, but you will have to be quick off the mark to catch them before they shut up shop, or they do what they have traditionally done, which is to spot a useful line and either hide it or discontinue it.
bfgstew:
Give component shop a call and see if they can knock something up for you, nothing ventured, nothing gained.
Martin (Admin):
These photos any use? - http://www.modelboatmayhem.co.uk/forum/index.php/topic,59977.msg630913.html#msg630913
mrlownotes:
I use these to drive 6V bow thruster and 6V monster servo from 12V SLA.
https://hobbyking.com/en_us/yep-20a-hv-2-12s-sbec-w-selectable-voltage-output.html
Selectable 5V/5.5V/6V/7V/9V and you can pull 20A through them. You would need 1 each for your 6V and 9V requirement.
Navigation
[0] Message Index
Go to full version
