Model Boat Mayhem - Forum
Author Topic: another newby question  (Read 417 times)
essexbill
« on: May 09, 2018, 08:43:01 AM »
Might sound daft to some.
But if you don't ask you don't learn.
Do I put a fuse between the battery and each ESC or between the motors and the ESC.
I did say it was a daft question but I have just come off a 12 hour night shift.
Re: another newby question
« Reply #1 on: May 09, 2018, 08:55:49 AM »
Between battery and ESC.  The only time that fuses are useful beyond the ESC is when there is more than one motor.
"Trying is the first step towards failure" - Homer (Simpson)
essexbill
« Reply #2 on: May 09, 2018, 08:57:05 AM »
Thanks for your reply , I am using 2 motors.
Tug Fanatic
« Reply #3 on: May 09, 2018, 10:10:16 AM »
But each motor has a separate ESC? If so you want a fuse between the battery & each ESC. eg 2 ESC each connected to one motor = 2 fuses - one between each ESC & the battery.
The fuse between the motor & ESC is only necessary if more than one motor is connected to one ESC.
