Author Topic: Prop Rotation  (Read 4209 times)
CGAux26
Prop Rotation
« on: June 09, 2018, 05:37:52 pm »
There are frequently threads with the central issue being which way props should turn, especially on twin screw boats.  For those who only go ahead except to stop, you may stop reading here.  If you do a lot of maneuvering, towing, docking, etc. this is for you.
Prop walk must be considered in setting up prop rotation.  An article is included that explains prop walk rather well.  So I am saying that outward-turning (going ahead, facing forward looking at the props) provides better handling.  I am not good at diagrams, so just imagine a twin screw boat with outward-turning props that needs to spin left on its beam ends.  Put the rudders hard to port, starboard engine ahead, port astern.  The bottoms of both props are now moving left, acting like car tires on the road to move the stern to the right.  Voila! A much tighter turn than if you did the same thing with inward-turning props.
https://www.sailmagazine.com/cruising/walking-the-prop
To make yourself a believer in prop walk take your single screw boat out and stop it dead in the water.  The give it a quick goose of throttle in reverse, then stop.  the boat's stern will swing left if it has a right-hand prop, or it will swing right with a leftie.  Again, the effect is caused by the bottom blades act like car tires.
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
Re: Prop Rotation
« Reply #1 on: June 10, 2018, 02:03:09 pm »
Agree 100%.
My father's 1:1 tug Meeching was twin screw, twin rudder. Screws turned outwards. As a youngster I spent days and days on board in the holidays and Dad, the other skippers and the mate taught me how to handle her, how to tow and much more. (It was assumed that I'd follow in the family tradition and probably end up as a tug skipper!) You could turn her on the spot with ease as described above, but you probably didn't want to use full rudder. You got to a point where adding more rudder seemed to weaken the turning motion. How that relates to model sized craft I don't know, I'll leave that to those with degrees in hydrodynamics!
I have two twin screw model tugs with independent control of motors. The bigger one has outwards turning screws but they're in Korts and I'm sure that negates some of the prop walk. But she'll still turn on the spot with one motor half ahead, one half astern and half rudder in the direction of the turn. The smaller one is Meeching, scratch built (very well!) by a modeller going from photos only - so he had no information of what she was like underwater. The screws are inwards turning on her but she still manages to turn well. As the shafts and props are out for a clean and lube, I'll swap the props over to match the real thing and see if it makes a difference.
CGAux26
Re: Prop Rotation
« Reply #2 on: June 10, 2018, 03:19:19 pm »
I will want to hear how your Meeching turns once you reverse the rotations.  I have no experience with korts, but I figured they would largely cancel prop walk.
My experience is a lifetime in 1:1 pleasure boats, up to a twin screw Grand Banks 42.  She had small rudders so more turns of the wheel were necessary to get a tight turn.  I also had an Albin 32, single screw with a long keel.  I chose a slip to keep her in so I could dock on the starboard side, since she had a big left hand prop.  In models, I have Springer that will turn on its own length with single screw and a fishtail rudder.  It backs severely to the right in reverse (LH prop), being short with no keel.  So I love the starboard side docking in steering competitions.
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
Re: Prop Rotation
« Reply #3 on: June 10, 2018, 04:01:56 pm »
I'll let you know, but with students' exams coming up it may be the summer before I get her back on the lake.
Single screw tugs - usually J P Knight's Kent or Kite - were always supplied as relief vessels when Meeching was up for refit and survey. So I got to handle them as well. My Dad was well used to them. You knew what they would do, ie left hand screw - ship's head will go to port when going astern. So you could take advantage of that when you wanted to do a snappy 180 in the river. Dad and I would usually do it as a 3 point turn. One of the other skippers had never handled a single screw ship in his career (drafted in from the passenger and car ferries) and Dad and I had to hold in the giggles as he took 9 goes to turn Kite around, fighting against the natural turning movement every time! :)
I haven't been a member of the local club for some years (more work commitments :( ) but did enjoy the steering contests. I have a small single screw tug with a Kort and fishtail and she's marvellous. 3rd place on my first go and 2nd on my 2nd. Would have got 1st on the 3rd contest, apart from one late entry with a small lifeboat that I'll swear had rudders and props all the way around, he was so darned good! :D
dodes
Re: Prop Rotation
« Reply #4 on: July 25, 2018, 07:56:55 pm »
We only had one vessel in the RMAS with a Kort nozzle and that was the Newton, one of the best handling single screw boats we had. When you went astern you simplyput the wheel hard over opposite to the direction you wanted the stern to go. The nozzle concentrated the direction of the prop wash, rather than relying on paddle wheel effect or rudder wash.
ivorthediver
  • Ivor the Diver
  • What ever Floats YOUR boat
Re: Prop Rotation
« Reply #5 on: November 15, 2019, 08:48:20 pm »
Thank you Gentlemen a very interesting thread of which I had no idea about so my thanks  :-))
RST
Re: Prop Rotation
« Reply #6 on: November 15, 2019, 11:33:15 pm »
...Don't worry, it comes up every 4-6 months and everything repeats on this and every other forum.  If you miss an argument for  / against or in / out or get confused between contra and counter rotating it is only a few weeks or months before it will come up again.  Almost guranteed there will be full discussion again soon so we can go through it all again, LoL.  Thankfully not much discussion between rotational and irrotational flow which if I remember was always key to propeller design, and a horibble subject.
ivorthediver
  • Ivor the Diver
Re: Prop Rotation
« Reply #7 on: November 16, 2019, 01:09:51 pm »
I'm sure your right but silver Surfers like me have short memories and shallow pockets sadly , but having been a modeller for more years than I care to admit ,its little tips like this that often slip through the cracks .
My Model was [ as most I build a hull purchased and then built from scratch after modification ] and I found that my knowledge is from my original suppliers who have served me well , and the use of a RN forum who described items I had never heard of , and members who had served on that ship and very helpful in expanding my scant knowledge .
My satisfaction is from the build and research , and then mastering the designs capabilities on the water .
I worked hard and needed a means of relaxing my mind ....and for me modelling was the answer ......and the friendship of club members has been worth its weight in gold .....had a lot of trouble getting into THIS Forum but having found my way around settling down and enjoying its threads .
Thanks for responding to my post and look forward to meeting more members and refining my current course which is tugs
ivorthediver
  • Ivor the Diver
Re: Prop Rotation
« Reply #8 on: November 24, 2019, 09:01:28 pm »
Whilst I'm sure its pilot error on my part .....but I altered my prop rotation to outward rotation of props on my tug , and found little change to speak of in steerage , but as I said it could be pilot error  by me having misunderstood the instructions proffered  {:-{
Perhaps someone could oblige me with some advice here please , as although the throttle settings remained the same the motors died at max power , in addition my turning circle was altered with a tendency to wish to go round in circles ..............very nice circles  but alarmed a nearby sailing boat .... <:(
rhavrane
  • Steam passionate collector
Re: Prop Rotation
« Reply #9 on: November 24, 2019, 10:03:49 pm »
Bonjour,
I have visited several shipyards to see how to install the propellers on my twin shaft steam tug : they have to be "super divergentes" = left one anti clockwise, so I did like that : https://www.youtube.com/watch?v=AMjCdql1xek
On the contrary, on twin propellers offshore speed boats with only one rudder, propellers are "super convergentes": https://www.youtube.com/watch?v=thx4LHy0BqI
Raphaël
ivorthediver
  • Ivor the Diver
Re: Prop Rotation
« Reply #10 on: November 24, 2019, 11:09:09 pm »
I am very grateful for your quick response to my request for help rhavrane , unfortunately I was unable to open your YouTube videos , but thank you for attempting to assist me .
rhavrane
Re: Prop Rotation
« Reply #11 on: November 25, 2019, 07:43:24 am »
Bonjour ivorthediver,
Never mind, my videos are just there to illustrate my opinion :
   - Working boats : super divergent  propellers
   - Offshore : supra-converging propellers
Raphaël
ivorthediver
  • Ivor the Diver
Re: Prop Rotation
« Reply #12 on: May 03, 2020, 03:20:08 pm »
Sorry in taking so long to reply but thanks for taking the trouble to help on this issue .
Page created in 0.104 seconds with 21 queries.
