I tried the servo first, N and centred it..i made sure it was a good metal geared servo, and then I seated it in the small box that it sits in, with a hole in the bottom of one end so that the lead will feed through...…..I make my servo boxes about 4 mm longer than they need to be so that they go in at an angle so as to be able to feet the cable through......BUT I make them as tight width wise so there is no lateral movement. the box which has a height about 4mm below the normal servo fixing lugs also for ease of getting them out, but in the case of the tender I think I made the height about 10mm lower than the lugs so it would fit in under a fixed deck and just higher than the box top.
I fitted the box into the space where I was going to have the servo and linked the rudders to the servo and made sure that it all worked...…………..but then I disconnected the servo tiller arm from the servo, took the servo out and taped the deck soundly to the hull with masking tape...…….I could then see if I could get the servo in and out once the deck was on...………..mission accomplished....……….far easier to do than any of my classic lifeboats I built...……
it could have been done a different way using bent link arms running under that rear cross beam that you see to a servo laid flat under the well deck floor using a mini servo, but at the time I had a mental block and thought i'd need all that space for batteries.
neil.
