Author Topic: What Timber to use?  (Read 2717 times)
Charlie
    • My Youtube Channel
What Timber to use?
« on: June 27, 2018, 05:37:30 pm »
What type of timber is most suitable for the planking on a double diagonal construction hull? Hull design is Round Bilge, so the timber has to be quite bendable.
Suggestions please.
Charlie
Re: What Timber to use?
« Reply #1 on: June 27, 2018, 05:51:24 pm »
Lime is often the wood of choice. Easy to work and flexible.
Charlie
« Reply #2 on: June 27, 2018, 05:55:01 pm »
Hi Colin,
Do you know of a good supplier? I looked on the SLEC website, as they always get recommended on here, but they don't appear to sell Lime.
Charlie
« Reply #3 on: June 27, 2018, 06:09:16 pm »
Hi Charlie,
SLEC market it as Basswood. In Europe it is Lime in the Americas Basswood but basically the same stuff. Can be confusing!
grendel
« Reply #4 on: June 27, 2018, 07:20:46 pm »
ikea market it as wooden venetian blinds, but boot fairs are also a good source, I can usually pick up 40 48" slats in a blind for a couple of quid, a fiver if they are really holding out, from each slat I cut a strip from each side avoiding the cutouts for the strings about 3/8" wide to 1/2" 80 planks for a few quid. if you get 3 blinds for a tenner that will keep you in planking for a good few models.
grendel
« Reply #5 on: June 27, 2018, 07:23:43 pm »
Charlie
« Reply #6 on: June 27, 2018, 09:10:26 pm »
Thanks Colin. Order placed with SLEC.
Charlie
Hi Charlie,
« Reply #7 on: June 28, 2018, 04:48:52 am »
If you are cutting your own planks, I have seen cedar mentioned a lot. I have used cheap pine (battens) as a source, just look for straight grained pieces and work around the pieces with knots. If you go to 3mm thick, a bit of steam helps to bend them. Pine is not ideal, but it is cheap; even it a bit harder to work with.
TailUK
« Reply #8 on: June 28, 2018, 08:36:17 am »
Hi Charlie,
You might also find it listed as Linden.  Some European countries call lime trees; Linden ( as in "Unter Den Linden")
Page created in 0.089 seconds with 22 queries.
