Author Topic: Jetty project  (Read 10593 times)
freelancer
Jetty project
« on: July 12, 2018, 02:59:22 pm »
Greetings from Canada's West coast
During my 13 years as a modeler I have been inspired by the mini-harbours created by European clubs, my favorite being the one at ST. Peters in Southern Germany. My friend Bryon Calverley and I do not have the resources to create such dioramas so we decided to downsize our ambitions and build a simple set of jettys which we could set up in a matter of minutes at a local pond. Because the pond had a gradient it was necessary to distance the jetty a few feet from the shoreline to an acceptable depth ( which equates to the height of my rubber boots ). The shorter jetty was designed to accommodate four different interchangeable buildings which match the role of the model alongside. In this way we no longer sail around in circles. The jetty buildings were built from .060 styrene and secured to the jetty by small pins glued to blocks of wood inside each building.
This was not a particularly expensive project but greatly enhanced the fun of sailing our various models. The challenge was to attempt a docking without destroying the model in the process.
Cheers from our local pond.Bryon Calverly and John Callin
freelancer
Re: Jetty project
« Reply #1 on: July 12, 2018, 05:04:18 pm »
Forgot to attach photo of the coast guard jetty and the URL for our BLOG
see more of our models at
longlakeharbour.blogspot.ca
The longer 60 in jetty
Walnut
Re: Jetty project
« Reply #2 on: July 17, 2018, 01:40:59 pm »
They are nice 'sharp' looking boats. Scratch built or bought over your way? I like the coastguard boat.
freelancer
Re: Jetty project
« Reply #3 on: July 17, 2018, 02:04:30 pm »
Hello Walnut
Thank you for taking the time to visit my thread.
I have many Coast guard supers, thesmaller one is a 39in model and the SAR design is a 45 in model.
The 39 in hull has three supers which are interchangeable and the 45in hull has two supers.
My models are all freelance designs, scratch built with GRP hulls, styrene decks ( 39in ) and superstructures...the 45in hull has 3mm Sintra decks and
styrene superstructures.
Drivetrains -  45in 2 x 755/40 Robbe motors driving two shafts with 2 x45mm 5 bladed props, the 39in-1 x 755/40 motor driving 45mm 3 bladed brass prop
Both hulls fitted with  single 12 volt SLA battery, 1 x Mtroniks 40 amp ESC , 2 ESC for 45in
Re: Jetty project
« Reply #4 on: July 17, 2018, 04:15:50 pm »
Now here is a coincidence. I have been mulling over something very similar this week.
Making buildings and jetties for lakeside scenes could be a side project for club members. Something to do for a change of pace, if you are waiting for parts or just fancy a change. Ideal for those club lakes with a concrete bank.
If clubs agree on a particular scale, the whole diorama scene can be extended over time, as any individual can add a new building. It will not matter that a lot of boats are different scales, as long as the buildings work together.  It is something that younger modelers can also get into. Maybe parents could pre-cut and kids can assemble. With a bit of extra design for pins or hinges, these buildings could even be flat-packed. That way members can easily bring both their model boat and building in the car together. At the end of the day, all can be taken home, and so hopefully no problems with the local council.
Not only will it make the waterside to the next level of modelling, it would also generate more interest from spectators, and may even attract a different type of modeller to the club. Maybe some Tamiya trucks or even tankies.
Just thinking at a tangent again.
freelancer
Re: Jetty project
« Reply #5 on: July 17, 2018, 08:17:21 pm »
Hi tigerTiger
It appears you belong to a model club with many youngsters...here are two additional ideas that may interest you for a club project
Before i designed and built the jettys, my first attempt to enhance the sailing at the lake was to build a facade with a Coast Guard theme.
The facade was built from plywood and it simply hung over the top rail on the wooden dock. It was fun however when the jettys were built this was no longer
a priority
2. The least expensive option for a club is to buy a 20 foot long piece of canvas,the same height as the distance from waterline to top of dock , some paints and have your club members paint a skyline of their choosing. The canvas backdrop would be unrolled and setup with weights in a matter of minutes. It is 2D but would give the youngsters an inexpensive project.
Re: Jetty project
« Reply #6 on: July 17, 2018, 09:06:05 pm »
I love your Jetties and feel like building one or two for my club!
Re: Jetty project
« Reply #7 on: July 22, 2018, 01:48:49 am »
If I had access to a piece of water I think I would too. :-)
I was thinking that at the scale of the ones above, old plastic pop/soda bottles would be great for flotation.
freelancer
Re: Jetty project - new deployments
« Reply #8 on: February 01, 2019, 05:08:25 pm »
Hello fellow modelers and in particular those who commented on the jetty posts
I have recently modified two jettys to match the role of the model being launched.
The jetty is positioned a few yards from shore parallel to the shoreline, held in position by two lead weights one suspended over each end.
This deployment is an option to the one which is attached to a long gangway secured to the shoreline. The advantage to this deployment is
that i can approach the jetty docking as accurately as possible and carry on in the same direction. As unrealistic as it may be, it is another variation which gives me more fun factor.
Check out more on our blog
Re: Jetty project
« Reply #9 on: February 01, 2019, 11:02:08 pm »
It looks good and enhances your hobby. Those are the main things Freelancer  :-))
freelancer
Re: Jetty project
« Reply #10 on: March 27, 2019, 03:09:34 pm »
Hi to all freelancers
This week I drove the 30 minutes to the lake with my new T-AGM variant as well as the long jetty. Unfortunately I forgot to bring the gangway which extends the jetty from the dock. However I was not deterred...I simply placed the jetty alongside the dock and sailed for an hour. The lake was quiet with very low winds. The jetty did not move far from its original placement allowing many attempts to dock and depart in the same direction..
As you are aware, I do not build scale ( replicas ) rather prefer to create my own designs. This model is a freelance version of a T-AGM , military parlance for a missile tracking ship. My design was inspired by the radar fitment of the USNS Observation island. That vessel , now scrapped had a large COBRA JUDY tracking radar fitted aft as well as a parabolic dish tasked with telemetry intercepts.
freelancer
Coast guard ammo jetty
« Reply #11 on: April 15, 2019, 11:43:35 pm »
Today I drove to the pond at the campground and found the conditions to be very windy. This was the first time in 12 years the wind was high enough to interfere with sailing. High coniferous trees surround the pond making it a great venue for sailing power boats.
My new ammunition jetty, designed to load 76mm ammunition into the focsle magazine of my 52 in WHEC ( High Endurance Cutter ) had a difficult time staying in position. I almost lost the jetty as the wind pushed it rapidly beyond my reach dragging the lead weights with it.
I have only one super fitted to this hull however it is built to a smaller scale than my other hulls so a new set of jetty warehouses was required to match the model. After 12 years of sailing this super I have plans to de-commission her in favor of a new modern Coast Guard design. That may be built and deployed by end summer.
freelancer
Research vessel and jetty
« Reply #12 on: April 23, 2019, 03:35:10 pm »
I have a 45in freelance research vessel ( AGOR ) in my fleet and as you have guessed there is a jetty arrangement to match the boat.
This is my interpretation of a Coast Guard jetty designed to launch a submersible deployed to test underwater sonar upgrades for the Navy fleet.
TugCowboy
Re: Jetty project
« Reply #13 on: April 23, 2019, 04:36:50 pm »
What a brilliant versatile Idea. I've been hoping to do something myself for the past few years but just can't get regular access to a decent bit of water to make it worthwhile. Your jetties are certainly good inspiration for when I can get round to it though, thanks for sharing.
Alex
freelancer
Hi Cowboy
« Reply #14 on: April 23, 2019, 05:01:12 pm »
Hi Cowboy
Thanks for taking the time to comment, pleased you like the idea. I understand the frustration of not having quiet water nearby to sail as the lake I prefer to sail at 30 minutes away is seldom quiet but when it is my friend Bryon Calverley and I are launching at 7am to get a full hour of sailing
before the wind picks up. Photography is always better before the bright sun hits the models. A friend of mine in another province is an avid modeler and adopted the freelance designs but found himself in your situation with no fresh water close by. He solved that problem by loading up his camper van and visited a distant campground on a lake. His one week,  twice a year, sailing was not ideal but satisfied his craving and gave him lots of time to design and build. I understand the freelance concept and the jetties are for a select few but if you need any help in design I would be pleased to help.  You are probably a keen tug fan and that hull lends itself to a wide variety of supers and jetty arrangements.
Cheers and good luck in your search for quiet water.
My next super and jetty will be built and posted in mid May ( Superyacht on a 39in hull )
freelancer
a new paint scheme for my 52in Coast guard cutter
« Reply #15 on: April 25, 2019, 10:56:49 pm »
Hello once again
When I sail a model for many years I often become bored with the colour scheme, primarily the hull. Such is the case with my 52in Coast Guard High endurance Cutter. As most of the worlds CG cutters have white hulls i decided to follow their lead and change mine from dark blue to white.
This new scheme will keep me motivated to sail this model for a few more years. Here she is pictured alongside the ammo jetty once again, on a more favorable sailing day.
Cheers from my freelance dockyard
freelancer
Medical Emergency on long lake
« Reply #16 on: May 07, 2019, 09:16:05 pm »
Hi all jetty enthusiasts and Newbies to my posts
This morning i drove to the pond and found the lake to be great, free of surface debris and the sun at a good angle for photos, low wind.
This morning i sailed my 39in Marine ambulance with a new jetty arrangement. In this scenario, i imagine a sailor in distress being transferred from a yacht and transferred to the Long lake visitors jetty where a land ambulance is waiting.
In the next few weeks my friend Bryon Calverley and I will be uploading many new builds as well as some new jetty configurations..
Re: Jetty project
« Reply #17 on: May 07, 2019, 10:37:56 pm »
Harbours and jetties give us boaters the same extra activity that model truckers enjoy. Something I really endorse. As a warship fan, I keep an eye out for a part built HMS Victory so convert into a depot ship/coaling hulk that people with warships could berth by and replen'. I have faint but usable drawings of HMS Agincourt (nineteenth century warship version) that was turned into a coaling hulk and festooned with cranes. It looks excellent.
I have enjoyed your build from day one and hope you have lots of fun with it.
freelancer
Driving Miss Maisee
« Reply #18 on: May 17, 2019, 04:23:01 pm »
Greetings from Canada's West Coast
You have heard of " Driving Miss Daisy " ??? Well this morning "Driving Miss Maisee" was the event on the pond. Maisee a Scottish Terrier was on the foc'sle acting as lookout during the maiden voyage of my latest super for the 39in hull. I was concerned that this newest super would be top heavy as it involved more styrene than previous supers however it did not affect stability. In fact it appeared to make the model a bit more stable...waht a relief. A few years ago I scrapped a superyacht and regretted that decision so it was with great pleasure that I now have a follow on superyacht that is high on my favourite list.
I no longer ask a printer to create cut vinyl lettering for my models and jettys . Now I create my graphics using a free graphics program INKSCAPE in full colour vector format , then use Windows snippet tool to get a JPEG low resolution copy. That file is loaded onto a memory stick and printed at the local photo kiosk for very little money , 6 dollars for 8x10 in  or 2 dollars for a 5x7 in. The paper is heavy gauge and waterproof, glued to styrene or Sintra with medium CA glue.
Cheers from my freelance workshop..Maisee says WHOOOF !!
freelancer
Drone squadron
« Reply #19 on: May 23, 2019, 10:22:04 pm »
Hi to all modelers
Anyone who follows military news will understand that drones are becoming a must have item in the fleet. Large drones are now deployed in the hangars alongside the helicopters on destroyers and I see no reason why my Coast Guard vessels should not have one. My 45in SAR cutter benefits from a drone embarked to conduct counter-drug operations and SAR. There are three cutters in 45 squadron, two are deployed and this one recently returned from a rescue mission ( LOL ).
This morning i arrived at the lake in very bright sun, not ideal for photos but I am not about to waste a sailing opportunity.
Cheers from HQ of 45 Squadron
Re: Jetty project
« Reply #20 on: May 24, 2019, 04:27:45 am »
mike_victoriabc
Re: Jetty project
« Reply #21 on: May 25, 2019, 08:56:30 pm »
Nice work there John - looks good.
freelancer
HazMat - Hazardous Materials
« Reply #22 on: May 26, 2019, 06:04:41 pm »
Hi to all modelers
This sailing session involved the Coast Guard Multi-Purpose vessel ( my 45in hull )  tasked with transporting HAZMAT from a dedicated dockyard jetty to a blast furnace somewhere many miles away where it would be turned into glass silicate. Where did the asbestos come from ? When the Navy scrapped all twelve 1960 era destroyers it was necessary to remove all the asbestos from the pipes below deck, engine and boiler rooms in order to sell the hulls to a distant nation. The build of the HAZMAT container and the jetty billboard was an inexpensive endeavour using scrap .060 styrene..total cost including the kiosk colour print for the billboard was approximately 13 dollars.
Cheers from my Freelance dockyard.
Re: Jetty project
« Reply #23 on: May 26, 2019, 06:29:30 pm »
 :-)) Looking fab. The Super Yacht with Terrier on board is 'Woofully' good  {-)
freelancer
Bryon's Lobster boat and Jetty
« Reply #24 on: May 30, 2019, 07:17:52 pm »
Hi to all modelers in particular those who enjoy seafood..LOL
After a few months of frustration waiting for low winds on Long Lake an opportunity finally arrived. The lighting was ideal and Bryon and I enjoyed a very early 6am sail just as the sun was rising behind the trees. The time is right to highlight one of Bryon's models. His large East coast lobster boat is one of my favourites. I suggested to Bryon that it deserved a dedicated jetty and he agreed so construction began a few weeks ago. Captain Bryon is a lobster fisherman and Miriam ( BRYMIR ) is the owner and operator of a seafood imbiss near a busy marina and fisherman's wharf. Bryon delivers fresh lobster each evening. The next morning it even attracted a super yacht from the nearby marina.
Yes it is fantasy but it adds a layer of fun. We would find it difficult to sail without a jetty. Bryon has another unique model and jetty combination which will be posted in the next few weeks, one which is likely to entertain all British modelers.
Cheers from Canada.
