Author Topic: Planet T5 Manual  (Read 2870 times)
The Old Fart
Planet T5 Manual
« on: July 27, 2018, 01:19:17 pm »
I'm looking for a manual for the Planet T5.
The links I've found are no longer active.
Specifically I'm looking for the binding and RX fault (flashing led) meanings.
Bob K
  • Bob K
Re: Planet T5 Manual
« Reply #1 on: July 27, 2018, 01:36:10 pm »
Please check this link for HTML version of full Planet T5 manual
https://www.manualslib.com/manual/929200/Planet-T5.html
If you could PM me with your email address I can send you the full PDF version of it
Cheers,  Bob k
bfgstew
  • Comfortably Numb
« Reply #2 on: July 27, 2018, 01:37:33 pm »
"Give me a ping Vasili. One ping only, please"
bfgstew
  • Comfortably Numb
« Reply #3 on: July 27, 2018, 01:38:52 pm »
Bob beat me to it...... %%
The Old Fart
« Reply #4 on: July 27, 2018, 01:59:45 pm »
Thanks guys,
Bob K
  • Bob K
« Reply #5 on: July 27, 2018, 02:07:01 pm »
We are always pleased to help.  I have emailed you the full PDF Planet T5 manual
Bob K
The Old Fart
« Reply #6 on: July 28, 2018, 11:58:51 am »
Back again....
Thanks for all your help so far.
This T5 is not mine but been asked to see if I can get it working.
It refused  to bind to known good RX.
So I put together a small spectrum analyzer. "just like that".
No output from the T5 aerial, no output from the RF board.
Scoped the input signal to the rf board, all correct as far as I can tell.
Voltage regulator correct.
Knowing that spares for these transmitters are nil, has anyone replaced the RF board with another type?
JimG
« Reply #7 on: July 28, 2018, 08:22:27 pm »
You could try an FrSky hack module, these have been fitted to many other transmitters. If the input to the rf module is OK then it should work.https://www.t9hobbysport.com/frsky-dht-2.4ghz-telemetry-diy-module
It would need FrSky receivers to work.
Jim
Dundee Model Boat club
The Old Fart
« Reply #8 on: July 28, 2018, 08:32:35 pm »
Thanks Jim,
I'll see what the guy thinks of convering the transmitter.
