Author Topic: PETER ARNOT V 4  (Read 1715 times)
MOG8
PETER ARNOT V 4
« on: August 22, 2018, 03:39:29 pm »
Good afternoon,
does anybody know the bore and stroke of the Arnot v4?
Thank you.
Giovanni
Giovanni
rhbrook
Re: PETER ARNOT V 4
« Reply #1 on: August 22, 2018, 04:46:19 pm »
Good afternoon Giovanni,
The bore of the cylinder is 5/16th inch (7.938mm) and the stroke of the cylinder is  13/16th inch (20.638mm).
Please note the dimension I have given for the stroke is the overall length of the cylinder, which is what I assume you require. As the cylinder covers project into the bore
the actual movement of the piston will be less.
I hope my explanation is understandable, but please feel free to contact me again if you have any further questions.
Roger
MOG8
Re: PETER ARNOT V 4
« Reply #2 on: August 23, 2018, 06:38:12 am »
Thank you Roger for your prompt reply.
The stroke could be about 13 mm more or less,  I do not know what could be in fractions of inches!
Giovanni
Giovanni
rhbrook
Re: PETER ARNOT V 4
« Reply #3 on: August 23, 2018, 11:34:31 am »
Yes - you are quite correct.  The plan shows the stroke as being 1/2 inch which is 12.70 mm.
Again, if you require any further information, please do not hesitate to contact me.
Roger
Geoff
Re: PETER ARNOT V 4
« Reply #4 on: August 31, 2018, 01:56:51 pm »
I built one of these a number of years ago. It was my first attempt so was somewhat frustrating but I got it going in the end and eventually re-built it and it runs extremely well. Peter wrote a series of articles in Model Boats which were quite excellent and took you through pretty nearly everything assuming you had never cut a piece of metal in you life. I learned an enormous amount from this project and eventually built my own designed in line twin double acting oscillator for a model of HMS Velox (1908 destroyer) which works very well and can still be seen sailing.
I had the pleasure of meeting him once at Papplewick Pumping Station many years ago. A very nice man indeed. If you check with MB you may be able to pick up copies of his articles which may assist.
Geoff
