Author Topic: Bending thin ply  (Read 2360 times)
Gardener
Bending thin ply
« on: September 17, 2018, 01:26:49 pm »
what is the best way to bend thin ply to form a curved hatch cover ?
Gardener
Re: Bending thin ply
« Reply #1 on: September 17, 2018, 01:33:37 pm »
Ply about 2.5mm thick
david48
« Reply #2 on: September 17, 2018, 01:38:01 pm »
What Radius do you require.
David
Gardener
« Reply #3 on: September 17, 2018, 03:06:02 pm »
Hi only a slight curve to match deck curve nothing drastic
grendel
« Reply #4 on: September 17, 2018, 03:51:34 pm »
I have managed to bend 5mm ply to accommodate the slight radius of a fore deck, but that is with a good support structure strong glue and stronger clamps, my cabin roofs are curved, but from 1.6mm ply, so you could do two layers (I find one layer curved is plenty strong) I have curved 0.8mm ply very slightly in two planes, but it constantly wants to spring back (once again cabin roof with very slight fore and aft cure as well as side to side).
Ply will naturally curve more one way than the other, so use this to your advantage when deciding on which way you will cut out of the ply.
Gardener
« Reply #5 on: September 17, 2018, 03:53:06 pm »
Big Ada
« Reply #6 on: September 17, 2018, 06:12:06 pm »
David
Try Steam.
Gardener
« Reply #7 on: September 17, 2018, 07:35:40 pm »
roycv
« Reply #8 on: September 17, 2018, 07:42:21 pm »
Hi I use hot water biscuit tins elastic bands hair driers. Go for slightly more curve than you need.  Stop the elastic bands making marks by using scrap wood.
Roy
Gardener
« Reply #9 on: September 17, 2018, 07:49:09 pm »
