On another tack, if you aren’t too fussy about scale on water looks...
The sponsons protrude further forward than the central hull, what’s to stop you using something like thinnish lexan between, and for for the length of the sponsons, creating a sledge /stepped flat hull effect?
With enough grunt she should plane on the back edge of the lexan step and the underneath of the jet drive outlet (or flaps either side).....handling might be interesting but it could work.
There’s another thread on here where someone 3D printed a jet drive and used a flat bottomed hull for experimentation that seemed to go well, you’d be replicating that hull shape after a fashion.
