I know at least one member here has it and I have some questions on it:
That would be me....
1. Does the mech. speed control have reverse?
2. The boat as designed takes 2 7.2v batteries. Are these wired in series to double the voltage, or parallel to double the amps?
3. Do the window stickers look better in person than they do in the pics? Same for the brass or gold (not chrome) fittings. In some of the Otherland pics they look crooked.
4. In general, would you recommend this boat? It looks to me like a decent cross between an ABS hulled speedboat and a scale model cruiser.
1. Yes, but I recommend a cheap waterproof electronic ESC like an mtroniks Viper 15A.
2. As designed, wired in parallel to double the amps, however I used a single 4300mah 8.4v pack mounted across the boat just above where the propshaft leaves the hull and enters the interior. It says 2 batteries, but that was from the days of max capacity = 1200mah, also much better balanced with one pack mounted as I described.
3. The stickers and gold are far worse than the piccies (!)
4. Excellent boat, goes very well, and yes, I'd buy another :) The hull needs a bit of trimming and gluing, but if you have opposable thumbs and have managed to type your question on a computer, it isn't beyond you to build this boat (no insult intended, just giving you an idea of how straightforward I found it!).
-Rob
-Rob
