Author Topic: printer  (Read 7388 times)
regiment
printer
« on: April 21, 2020, 03:12:26 pm »
to copy or to scan whats the difference  from a 89 year  thickey  have just been given a printer
Taranis
  • Balne Moor MBC
Re: printer
« Reply #1 on: April 21, 2020, 03:29:01 pm »
I believe that SCAN doesn't print but produces and image of the document to view on a PC
Copy will scan the document and print it out
ANDY
TailUK
Re: printer
« Reply #2 on: April 21, 2020, 03:51:11 pm »
Usually copy refers to duplicating a document or picture that's already in the computer. The images can be imported into various applications and printed out.  A scan is the term used when a physical document is digitised using a scanner or photographed digitally to allow it to used in the computer.  It might be more useful if you could describe the job you're trying to do.
grendel
Re: printer
« Reply #3 on: April 21, 2020, 04:23:13 pm »
copy does a physical copy on another piece of paper, scan does a copy into your pc as an image you could for example post here.
Re: printer
« Reply #4 on: April 21, 2020, 07:13:54 pm »
What printer regiment some actions can be controlled from your computer. Knowing the model  someone may be able to help from the online manual if you get stuck.Better still might even have the same printer.
grendel
Re: printer
« Reply #5 on: April 21, 2020, 07:25:18 pm »
I recently bought an hp colour laserjet, basically you went to their website, hit go and it pretty much did it all for you wirelessly through the webpage it even was able to set it up for my tablet.
Taranis
  • Balne Moor MBC
Re: printer
« Reply #6 on: April 21, 2020, 07:35:13 pm »
You could just push each button and see what happens.  {-)
ANDY
Re: printer
« Reply #7 on: April 22, 2020, 08:55:10 am »
A printer prints what you tell it to print from the computer.
A scanner makes an image of the piece of paper that you have given it to read and stores it on the computer for you to use later.
A lot of present day printers are "3-in-1" devices that have a printer and a scanner in the same box.
Some of them let you scan a document and print it directly, without seeming to go through the comuter.  That is copying.
Re: printer
« Reply #8 on: April 22, 2020, 12:06:14 pm »
This is my Canon MG2550S.
It copies paperwork put on the glass panel, either in colour or B&W, and prints it out on paper fed from the back i.e. a photocopier.
It scans the paperwork placed on the glass and I can put the scan into a file on my computer, I also convert the scan to PDF format when I am archiving documents like pension paperwork, bills etc.
It prints anything I select for printing - including the scans previously done and MS documents etc.
Oh and it cost only £30 from argos a couple of years ago.
regiment
Re: printer
« Reply #9 on: April 22, 2020, 02:13:05 pm »
hi to you boffins my printer is an   epson 442  nice for a freeby would like a manual for it
Re: printer
« Reply #10 on: April 22, 2020, 02:19:27 pm »
regiment
Re: printer
« Reply #11 on: April 22, 2020, 03:48:22 pm »
hi colin cannot see any thing about manuals
Re: printer
« Reply #12 on: April 22, 2020, 04:06:03 pm »
Sorry Gordon, try this page. It has a link to the user guide and startup guide. (a bit further down under the picture) click on either one and then the Dowload button on the right hand side.
https://www.epson.co.uk/support?productID=20006#manuals
simple
Re: printer
« Reply #13 on: April 22, 2020, 09:18:19 pm »
Gordon,
For all my Epson printing needs I use Epson Easy Photo Printer. This software is from Epson and used to be supplied with all their printers. Should work fine for your printer. Do not need anything else.
here[size=78%] is the link for the small but easy to use software.[/size]
https://epson-easy-photo-print.apponic.com/
Re: printer
« Reply #14 on: April 23, 2020, 08:26:58 am »
Colns link leads to the required software, known as drivers.  If the setup disc didn't come with it, you will need to download the drivers and install them.
One piece of software that is important is Epson Scan, a handy utility for doing the scanning.  The Easy Photo Printer is fine if you fon't have anything else, but the printer/scanner will need the full set of drivers.  Being an Epson, they will probably need installing all in one go.
Mine is a much lowlier machine that I got purely for the scanner, I have better printers that don't cost an arm and a leg for ink when I need to use paper.
