Author Topic: Engine Identification  (Read 4083 times)
kiwimodeller
« on: May 03, 2020, 11:12:24 pm »
Hi, can anyone identify this unfinished engine. It is unusual in that it has standards made from round rod and it has vertical round piston valves where the slide valves would usually be. Hoping to find plans so it can be finished. Thanks, Ian.
steamboatmodel
Re: Engine Identification
« Reply #1 on: May 04, 2020, 04:39:24 pm »
Is it a piston valve engine?
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
kiwimodeller
« Reply #2 on: May 05, 2020, 12:22:27 am »
Yes it appears to have round piston valves vertically mounted up each side. I have a Saito piston valve engine but they are mounted horizontally along the top of the engine. I have never seen this configuration before.
steamboatmodel
« Reply #3 on: May 05, 2020, 01:59:25 am »
Can you post an end view?
the engine does look familiar, but I can't put a name to it.
Gerald.
kiwimodeller
« Reply #4 on: May 06, 2020, 03:37:20 am »
Hope this helps, I am having the usual problems resizing photos!
steamboatmodel
« Reply #5 on: May 06, 2020, 04:08:10 pm »
I think I may have plans for that style, it may take me a couple of days to find it.
Gerald.
steamboatmodel
« Reply #6 on: May 09, 2020, 05:14:26 pm »
I think I have narrowed it down to one of two engines;
 TWIN-CYLINDER STEAM ENGINEBy Julius de Waal
https://www.modelengineeringwebsite.com/Twin-cylinder_steam_engine.html
The One I think it really is Steam Ahoy Twin Cylinder Steam Engine by Stan Bray.
I have found a photo copy of the instructions, but can not find a pdf of it.
I will try scanning  the photo copy I have, it may take a couple of days.
It was published in World of Model Engineering #5
Gerald.
kiwimodeller
« Reply #7 on: May 11, 2020, 10:14:16 am »
Thank you for your efforts Gerald. The De Wal engine does look similar but different in the inlet and exhaust areas. I have had a drawing from the Stan Bray book sent to me but it is actually an MB 22 engine by Malcolm Beak and again similar but not the same although of course there may be other engines in his book. The search continues. Regards, Ian.
steamboatmodel
« Reply #8 on: May 13, 2020, 06:30:56 pm »
Gerald.
I have sent you a PM with a link to my dropbox where I have loaded scans of the Steam Ahoy, they were too large to upload here.
Gerald.
kiwimodeller
« Reply #9 on: May 19, 2020, 05:20:37 am »
Thanks for all you efforts, that certainly looks like the strange little beast. I will see if anybody in out club has the Stan Bray book. It would be interesting to know if anyone has tried it in a boat. Thanks again, Ian,
steamboatmodel
« Reply #10 on: May 19, 2020, 03:42:17 pm »
Hi Ian,
It was published in World of Model Engineering #5, one of a series of Magazines that was published a while back. I may even have the start of one of them. I was given some parts which included the start of one, but the threads were all BA which I don't have any taps and dies. The fellow who gave me the parts had completed one and installed it in a 48" Launch which I built a horizontal boiler for. When I brought the Boiler to him he gave me some parts and material as well as paying for the boiler in cash.
Gerald.
kiwimodeller
« Reply #11 on: May 21, 2020, 05:54:27 am »
Thanks again, I was able to download some but not all of the article in your drop box (probably my lack of compute skills) but hopefully a member of the boat club will be sending me a copy of the article. I actually have two of the engines, both finished to the same stage. I have an 8" x 3" (200 x 75) boiler sitting around which I was going to try with one engine but I might just give it a go with both engines depending on what the bore and stroke is. Thanks again for you efforts, regards, Ian.
frazer heslop
« Reply #12 on: May 21, 2020, 03:15:07 pm »
You can download it from the Model Engineer site . Its is for non subscription download part 1 subscription part 2
https://www.model-engineer.co.uk/news/article/world-of-model-engineering-issue-5--parts-1-and-2/5812
steamboatmodel
« Reply #13 on: May 21, 2020, 04:03:55 pm »
Thank you Frazer,
I had searched all over for a pdf of that article.
Gerald.
frazer heslop
« Reply #14 on: May 21, 2020, 08:16:52 pm »
I just need to find the boiler drawing as its not in the free bit
cheers
kiwimodeller
« Reply #15 on: May 25, 2020, 10:14:42 am »
Thanks very much to both, I have managed to download and print off the complete engine file. Now to get on to finishing the engines. I have a cunning plan that means my friend can have one engine if he machines both. Thanks again, Ian.
Page created in 0.032 seconds with 21 queries.
