Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: Celestine ( Deans Marine )  (Read 59484 times)
cos918
Re: celestine
« Reply #150 on: October 11, 2017, 09:52:06 pm »
bridge
cos918
Re: celestine
« Reply #151 on: October 11, 2017, 10:11:48 pm »
lighting
cos918
Re: celestine
« Reply #152 on: October 11, 2017, 10:14:29 pm »
Rough weather sailing at Mayhem 2017
https://www.youtube.com/watch?v=Tb1bTfMnhCY&feature=youtu.be
Re: celestine
« Reply #153 on: October 11, 2017, 11:00:35 pm »
That slow-mo video looks so lifelike  :-)).......considering such high windage profile..... Derek
Brian60
Re: celestine
« Reply #154 on: October 12, 2017, 08:21:32 am »
Looking good, especially with the illumination. The bridge deck, is the floor really blue? Most modern ships now have a pseudo wood laminate floor laid, even in offshore vessels.
hama
Re: celestine
« Reply #155 on: October 12, 2017, 10:23:50 am »
Nice job on the lighting,  it really ads to the realism! Liked the video too, she handled well considering the bad weather. Perhaps the camera on top had some  bad influence on the stability?
Keep up the good work!
Hama
cos918
Re: celestine
« Reply #156 on: October 12, 2017, 10:59:16 am »
Thanks for the kind words.
The weather at Mayhem 2017 was not kind . There was gusts blow across the pond . Given her high beam as she is a ferry she handle well. She tends to roll a bit then did in. I dont think she would roll over.
Still got a lot more lights to go .
Brian
dont know what colour her bridge floor was . just grabbed the first spray can which was blue and painted the floor . Looking in you dont see much of the floor any way .
john
cos918
Re: celestine
« Reply #157 on: January 07, 2018, 08:55:14 pm »
Went to restart work on Celestine . Thought must have a detail catch up of were I am on the electrics and were i want to be . looked at the PDF of the switching unit . common + switched neg , oh dear . Spent 4 hours tracing and checking the all ready fitted wires . knocked a few bit off ,more to fix later . After 4 hours found out a few things . One it wired switched positive neg common . This can be fixed by using relays . Second do a detailed wiring diagram and fill in the colours of the cables as you fit them . Dont chop and change colours ) .
so some relays have been ordered . will check these when I come back from work next week . Then do a detail wiring plan . Then start wiring up that bridge . need to find a connector to for the bridge wiring harness , needs to be about 20 way . might look at old computer cables etc .
cos918
Re: celestine
« Reply #158 on: January 14, 2018, 09:04:51 pm »
Relay board arrived. Spent a few hours on the web working out the connection. Tested it works fine. So programmed the RC 7 way multi switch. Connected it to the relay. Work fine. Now I can switch 7 relays on one at a time in asecending order.
This means the switch is switched negative. Celestine lights are switch positive. The relays will take care of that.
Next up is to wire this relay board and multi switch on a permanent base and wires and terminals
john
cos918
Re: celestine
« Reply #159 on: January 18, 2018, 07:13:36 pm »
made a start on that spaghetti wiring LOL about 40% of the way there .
cos918
Re: celestine
« Reply #160 on: January 29, 2018, 08:05:25 pm »
Well more wiring done. Started doing some testing and it looks great.
We have red white red restricted manoeuvring by draft
Triple red restricted manoeuvring by size
Green pilot on board
White running light
Port starboard lights
Four flood lights
Out side lights
Bridge lights
Still got inside lights and spot light to go.
Need to look in to multi plugs to see what can be used
john
cos918
Re: celestine
« Reply #161 on: October 04, 2018, 09:37:19 pm »
Been a while since i looked at this thread .
Tested the lights all worked well . add a few more to the bow area .
Then built a dock for her .
Got her ready for Mayhem .
there is a video of the lights but it is only on face book .
cos918
Re: celestine
« Reply #162 on: October 04, 2018, 09:41:47 pm »
went to the Mayhem show with Celestine and Finnjet. Meet up with Ali who had a wonderfull north sea ferries
cos918
Re: celestine
« Reply #163 on: October 04, 2018, 09:49:45 pm »
Next up had a broken wire in the ferry were you can get to LOL. This ment cutting the deck. Here I decided to make the opening bigger. I was not 100% happy with the wiring so it was all ripped out and re desigined.
Also the stern ramp was not clossing tight so I made an adjuster on the actuator
john
cos918
Re: celestine
« Reply #164 on: October 04, 2018, 09:54:44 pm »
next up started to redesgine the electrics and trial fitted it . New deck hatch was made with magnetic cataches
cos918
Re: celestine
« Reply #165 on: October 04, 2018, 10:00:37 pm »
Next up was painting the deck and Starting to tidy her up . Wiring was finished and tested . 3 secreat switches were added.
cos918
Re: celestine
« Reply #166 on: October 06, 2018, 10:11:31 pm »
Wired up the Led. Forgot to cut the copper track below the resistor. Leds went pop.  Oh dear. Well new fitted and tested. Very pleased. I could do more lights but I think I will call it a day.
Tafelspitz
  • Model Boat Bedlam
Re: celestine
« Reply #167 on: October 08, 2018, 06:44:15 am »
Amazing work! Looks just like the real deal  :-))
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
hama
Re: celestine
« Reply #168 on: October 08, 2018, 09:21:08 am »
Totally agree! Looks like a real vessel, well done!
Hama
cos918
Re: Celestine ( Deans Marine )
« Reply #169 on: October 31, 2018, 10:18:05 pm »
Hello
thanks for the nice word sWell since the last update it has beeen hand rails . I relly dont like them hard work but they are all done. Each one is soldered . Now started on the cranes
cos918
« Reply #170 on: November 11, 2018, 09:31:24 pm »
Next up was detailing and adding cars. I use clear sheet and hot glued the cars down on to the sheet. This made it easier to set up.
She need a nice stand so one was made up out of some left over Iroko wood I had and topped with rubber .
The Stairs were finished off as well .
At The Warwick show her rudder broke so this was fixe din one evening
cos918
« Reply #171 on: November 11, 2018, 09:37:16 pm »
A few photos from the Warwick show
Her lights really showed up well and her smoke worked well .
hama
« Reply #172 on: November 12, 2018, 01:12:07 am »
She really look magnificent!
And that ferry meeting, wow I would have liked to seen that live.
Hama
cos918
« Reply #173 on: November 12, 2018, 05:08:34 pm »
Hi Hama
Thanks ,she is getting there . I hope to have her finished this year.
This is the second time we have had a ferry slot at the Warwick show . They cerently pleased the crowds . It is great to see boats of the same type on the water at the same time . Hopefully in the next few years we will get more thanks to the hard work of Carl of linkspan models
« Reply #174 on: November 12, 2018, 09:16:02 pm »
Some great images John  :-)) ......we see with your vessel, the auxiliary engine [generator] exhaust sets down aft as usual, however is this an emergency generator [10" diameter] exhaust just behind the bridge?
Pages: 1 2 3 4 5 6 [7] 8   Go Up
