hi all been doing a bit more while i am off work with this cold.
1 put in froward card deck / void , filled with foam then trimmed and add a wooden deck.
2 made the rear battery trays
3 put a limit stop on the actuator.
4 went to install the actuator and realized my plan would not work so had to have a rethink. Came up with a new plan and will test on Sunday.
5 did a float test and found that one of the bow thruster has developed a leak
. As you can see there is no room down there now so not to sure how i am going to fix that one . might try smearing some black silicone around the joints in the thruster.
john
