Andrew,
The new hard drives are now running at 10k rather than 7.2k. Don't believe all you hear about bearings and hard drives.
I used to be on the ground floor making protos of the damned things, and I can tell you now, they might sound all singing all dancing, but they will be the cheapest thing that they can get hold of to keep the price down, they have most probably done away with the balls completely and stuck in a chamber of oil, and called it some super duper thingymajig name to make it sound great, designed to run so many hours and then fail, just enough to get them thru the warranty period.
Caps,
I have had a total rethink on the turbine and have designed one in my head that puts all rotors together as one unit, I thought that seperate units would cause a balancing problem at such high speed. But it does mean that machining tolerances will have to be fairly tight (about 0.002" rotor to case clearance) also the exhausts will start to scrape much earlier (about 45 deg after inlet). Easier to make, more compact and only two bearings, both on the outside, so will have a better chance of keeping cool.
Your props will hopefully need about 400 to 500 rpm top wack, so a gear ratio of say 100 to 1 reduction would be the most that would be required. Need to see the speed output by the turbine before that is needed.
I have already geared up the making on a model engine site that I use, it will be after I have finished my latest project, and should take about a week if my health holds up. Then we should see if it comes up to expectations. The difficult bit will be making the throttle/reverse unit for it, but again the idea is locked in my brain at the moment, but it should work. As you know, I make on the run, piccies are for those who don't know what they want to do.
