I have used the pins recovered fron dead 13amp plugs for quite some time. Just a bit of work with a small drill and a big file, and you have a nice brass arm with a brass screw. Sailing in salt water like I do, this is a valid consideration, a steel tends to rust solid on the way down to the pond.
Most model shops stock plastic arms with a brass bush and a grub screw.
