About mid Jan 2016,I was asked if I would like to do a deal with one of my boats against a Mersey,I said I would have to look and see,when I got to place where the Mersey was,I could not believe what I saw and what state it was in (I nearly cried)I knew the original owner/builder of this boat,he took 5 yrs & over 4000 hrs to build,I was told it's been left in a garden for over 4 1/2 yes, (by the state of it I can believe it),now I purchased the boat took it back home then explained to the wife (cost me a shopping trip)it is going to be a challenge,lots of bits broken,but can be repaired,it had over 6 carrier bags of fittings I started with the carriage,then the talus and finally the boat,lucky for me the original builder sent me the photos of the build in which I was truly great full.Now
1. Carriage. : old tracks removed,old wheels removed,welding bits that needed welding,front wheel assembly was broken,now I done the welding that needed doing,then i put new tracks & wheels on,new rope and carriage was done
2.Talus : 4 carrier bags of broken bits,tracks needed repairing,the wiring had to be replaced as it was black,so I wired it up all lights working (only had to replace 1) it is now radio controlled with working lights
3. Mersey : started with the cabin,again lots of fittings come adrift,fitted the windows back in,repaired the mast and once fittings were all in the right place, I lit it up so now all lights working inside/outside,I did change the name from Scarborough boat,to Skegness lifeboat (it's my nearest station),now I then started on the hull,changed colour,fitted railings that had broken off,repaired what needed doing (Areials, hatches,trim tabs etc) all I have to do now is change motors as they were seized and put radio gear in and she will be ready to go on the water.
1:6 scale. Talus 33" Carriage 69" Mersey 78", figures are Action men/ G I Joe.
