Pages: [1] 2 3   Go Down
Author Topic: Boatmadman's superspringer  (Read 19320 times)
boatmadman
« on: December 15, 2007, 03:16:05 pm »
HEH, HEH, HEH   O0
Re: Boatmadman's superspringer
« Reply #1 on: December 15, 2007, 03:22:29 pm »
Blimey, a racing Springer!  :o
Martin
Arrow5
« Reply #2 on: December 15, 2007, 04:20:47 pm »
Nah, too fat for a racer.  Behold the "Springalong" , from re-cycled CD rack that was just a convenient 9" longer than a regulation Springer. Just used front and rear profiles and added flat mid-section.  Shown with "Maid" top to show difference. Planning two standard 540, (not sure about Korts) and a streamlined look. Started yesterday, finished by spring or earlier if Santa is nice to me. ;)  Nice work Boatmad, what is the overall size of yours? Any ideas yet about the top ?
..well can you land on this?
boatmadman
« Reply #3 on: December 15, 2007, 04:37:37 pm »
Mine is standard size, except running gear.
Not started the top yet, will wait and see what 'springs' to mind.
Arrow5
« Reply #4 on: December 15, 2007, 07:55:22 pm »
"...springs to mind"  {-)    I thought your SS was bigger somehow. Whose Korts, in case Santa is reading this ?
« Reply #5 on: December 17, 2007, 07:13:56 pm »
Topic split as I felt Wee Johnny should have his own thread
Arrow5
« Reply #6 on: December 17, 2007, 08:12:19 pm »
Thanks for link to Korts by the way. O0
boatmadman
« Reply #7 on: December 27, 2007, 04:56:23 pm »
Righto, some progress now:
here you will see the superstructure pretty much built, ready for filling and sanding, propshafts dry fitted with the secret new type of prop I am developing  O0
You will also see the radical location for the drive motors, transmission is top secret yet!
Mr Andy
« Reply #8 on: December 27, 2007, 05:08:23 pm »
Ian what size knozzles are you using?
Andy. ;)
Arrow5
« Reply #9 on: December 27, 2007, 05:25:05 pm »
It is looking suitably brutal, I do like the big funnels, hints of a massive diesel below.  Are the korts mounted in a block of resin ?
boatmadman
« Reply #10 on: December 27, 2007, 05:49:58 pm »
Andy, the korts are 50mm jobbies.
Arrow, the mounts are indeed in a resin block, araldite mixed with microballons - seems to work ok.
Mr Andy
« Reply #11 on: December 27, 2007, 10:40:53 pm »
Blwdi heck won't they bury the back end in the water? ???
Andy. :)
Arrow5
« Reply #12 on: December 28, 2007, 04:59:39 pm »
Nope , micro-balloons are all air so resin wont be heavy. besides with the well known diving-when-under-power characteristics of the Springer are considered , it could be a good thing to be slightly tail heavy.
Mr Andy
« Reply #13 on: December 28, 2007, 07:02:49 pm »
I'm off to the shop tomorrow I'll take my new hull with me and weigh up my choises.
Andy. :)
Arrow5
« Reply #14 on: December 29, 2007, 02:06:49 pm »
Hey Boatmad:  Big funnels need smoke, try some www.robotbirds.com smoke pellets(see www.putfile.com/Arrow5). Need metal tubes though, they burn very hot, will melt plastic !
boatmadman
« Reply #15 on: December 29, 2007, 04:36:45 pm »
very impressive, but if my engines smoked like that I would get the sack!  ;D
Arrow5
« Reply #16 on: December 29, 2007, 07:10:12 pm »
Yeah i forgot it wont be a steam engine, hee hee {-)
Mr Andy
« Reply #17 on: December 29, 2007, 07:40:10 pm »
Just waiting on the korts now I feel 50 mm is to big for mine so I'll go down a bit, purchased two 500 motors and other parts earlier 121 Squids and I've not finished yet. ???
boatmadman
« Reply #18 on: December 29, 2007, 08:04:21 pm »
Mr Andy, NEVER keep a total of the cost of your models - it'll scare the pants off you!
even more important - never, never, never tell swmbo the real cost!
boatmadman
« Reply #19 on: January 11, 2008, 05:36:03 pm »
And here we have a little progress at last on the drive train. Photo's show range of steering, the shaft end bearing, the steering linkages and lining up prior to glueing.
Mr Andy
« Reply #20 on: January 11, 2008, 05:54:37 pm »
Looking good Ian, I'm still unable to continue, not for much longer I hope. O0
As for keeping tabs on cost I agree wholly, don't.
Andy.  :)
Tugboat Andy
« Reply #21 on: January 11, 2008, 06:36:37 pm »
Great looking boat, but then again I am partial to kort nozzles.
What size propellers are you using.  They appear to be 45mm?
Keep up the good work!
boatmadman
« Reply #22 on: January 11, 2008, 06:55:09 pm »
yup, Andy, 45mm props in 50mm korts!  O0
Tugboat Andy
« Reply #23 on: January 12, 2008, 05:11:39 am »
I am trying a Raboesch 50mm prop in a robbe kort nozzle.  It seems that the 50mm prop may require fine tuning to ensure it does not bind.  I am afraid I may have to run the grinder around the blades to get the correct fit after the final installation. But, while the rudder tube is still loose, there is no binding and it turns fine.
I like your use of micro-ballons to build up around the rudder tube. I'm thinking about doing the same with some sort of removable form.  ;)
Do you have any idea what kind of motor you will use for power?  I tried the Titan 550 1:1 turning a Graupner 50mm 4-blade in a nozzle on my last boat. It moves pretty good but the motor will get quite warm. There is no easy way to cool the motor because of the kort nozzle.  :'(
djrobbo
« Reply #24 on: January 12, 2008, 12:28:38 pm »
Hi andy....have you thought of trying to cool the motors by using a seperate water pump.....water pick up can be from anywhere under water and can continue to run even when stopped........just a thought
       regards....bob.
Pages: [1] 2 3   Go Up
Page created in 0.094 seconds with 22 queries.
