Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: Quick Hints & Tips!  (Read 186988 times)
roycv
Re: Quick Hints & Tips!
« Reply #125 on: February 09, 2018, 01:19:13 pm »
Hi all, many of us are members of the Automobile Association, one of the benefits is the 10% discount at Halfords, where many of us get our paints from.  Just show your membership card.  Also there is a 20% discount I think in M&S shops on the motorway.
regards Roy
RAAArtyGunner
« Reply #126 on: February 12, 2018, 06:09:29 am »
Mate,
It's a bit far for me to travel  O0 so will have to give it a miss %) %) {-) {-)
« Reply #127 on: March 16, 2018, 09:20:24 am »
There was a thread on hot glue guns recently. I pointed out that some have a terrible stand.
Today, while using hot glue, I had one of Homer's Doh! moments. Hot-gluing some wood scraps together I got my solution.
So small it even fits in the glue gun box.
Walnut
« Reply #128 on: April 29, 2018, 02:48:52 pm »
Apologies if this has already been covered. I found this on a French model boats facebook page. 2mm cotton or similar, stretched or wrapped around sockets and covered in superglue, then sprayed to suit.
birlinn
  • Old git in a garage
Re: HINTS N TIPS FOR EVERYDAY USE.
« Reply #129 on: August 13, 2018, 04:52:11 pm »
When applying Deep Heat or any similar pain reducing cream to any part of the body, always...but always, wash your hands before going to the heads to take a pee.
It don't half make you hop about if you don't, I can assure you...   :o
And switch the light on before going to the bathroom cabinet for Germoline if you suffer from piles. You might just pick up the Vick by mistake.....Not me, but a work colleague- we chuckled, the rotten lot we were.
« Reply #130 on: August 13, 2018, 05:22:15 pm »
TMI,  {-) {-) O0 O0 O0
Andy M
« Reply #131 on: March 05, 2020, 11:01:16 pm »
My mate had rubbed deep heat on his thighs, then pulled up his joggies, smearing the cream onto his privates, his wife came back home to find him sitting on the couch with them cooling in a saucepan of water.  ok2
« Reply #132 on: March 16, 2020, 10:07:12 pm »
...... "My mate" .... Hmmmmm !!!
coch y bonddu
« Reply #133 on: March 16, 2020, 10:42:21 pm »
classic Andy M a m8 of mine did that down on a security job working down in glast o a few years back and is now nicknamed great balls of fire,he had taken his glasses off in his tnt and just grabbed what he thought was savlon it was dark as well You can imagine the screaming and him running around the camp site screaming in paint a slight and night i will never forget
BeeJay UK
  • Norfolk 'n Good
« Reply #134 on: June 18, 2020, 07:33:03 pm »
All the comments about the hazards of Superglue reminds me of one of our unfortunate firemen at RAF Hospital Wroughton.
Rather foolishly he had put a tube of Superglue in his trouser pocket. Rather unusually he had a shout, pulled on his fire kit and jumped in his fire engine. Somewhere along the line tube burst, releasing Superglue where you didn't really want Superglue.
It took us humble medics in Casualty about 4 hours to separate his scrotum, his inner thigh, his undies and his trousers.
And the shout, malicious breaking of a call point on the officers married quarters estate. Officers children are no better behaved than any others.
And another anecdote you may not want to hear. I once mistook Ultrabrite toothpaste for my Nupercainal pile ointment. Trust me that is a mistake you only make once.
Fastelectrics
« Reply #135 on: August 26, 2020, 10:17:25 pm »
If you are going to buy a new multimeter, get one that switches itself off after a period of time. Any additional cost on the price of the meter will quickly be offset by the savings on replacement batteries.
« Reply #136 on: August 27, 2020, 12:08:09 am »
 O0  Brilliant & very true!   :-))
BeeJay UK
  • Norfolk 'n Good
« Reply #137 on: August 27, 2020, 12:18:02 am »
Just one of the reasons I will only buy analogue multimeters, as long as you don't leave the dial on ohms then there is no battery drain.
The other reason is that I just don't like digital ones, I find them too slow to stabilise the readings and when using it for continuity checking a moving needle is much more visible than LCD numbers.
I've got 4 analogue meters, one each in the car, caravan, workshop & 'pond box', never far from one.
« Reply #138 on: August 27, 2020, 12:37:23 am »
I don't need to use meters with any real accuracy anymore, just:
  Live, dead or burnt out.   :embarrassed:
BeeJay UK
  • Norfolk 'n Good
« Reply #139 on: August 27, 2020, 08:19:29 am »
Same here, 'go - no-go'. Needle moves, go, needle doesn't move, gone.
Tug Fanatic
« Reply #140 on: August 27, 2020, 08:29:44 am »
You don't use it to measure ohms, amps and volts frequently?
KenniiP
  • Kensboats.
  • Fast or slow, boats are best!
« Reply #141 on: August 11, 2023, 06:09:21 pm »
A few tips from me. To cut and seal the edges of ripstop pr polyester sail material, I use an olfa rotary cutter blade fitted into a brass fitting which I made, and which clamps to an electric soldering iron. This allows you to cut and seal curves on sails etc very easily but also has other applications, such as running around a template to burn an outline onto wood or plywood which will not rub off as pencil will.
Wanting to reproduce a hull from an old glass fibre mould, but in plastic foam - do not ask - I waxed the inside of the mould well and filled it with expanding gap filling DIY foam from a can. I left it overnight to cure, and it released easily from the heavily waxed mould. I used the foam hull shape as a plug to build a lightweight hull from gummed paper strip, which once removed was later covered with stretch polyester cloth impregnated with epoxy resin. A super lightweight but strong hull resulted.
Bending Perspex. I made a few yacht stands from clear Perspex. These show the boats lines off perfectly. To bend the Perspex accurately I cut a narrow slot in a piece of six mil MDF, mounted the Perspex behind the slot at the proposed bend point, and heated this area with a hot air gun, kept moving and from about five inches. Once hot, the area of the Perspex under the slot will bend easily to whichever angle you require, but do not overheat, practice on a scrap first. Support the Perspex on a piece of MDF as you bend it to keep it flat - and wear gloves too, this stuff gets really hot! Carefully designed, perspex mounts can be used screwed against a wall to give the impression that your boat is floating in space!
Restoration saves space in the landfill!
« Reply #142 on: August 11, 2023, 06:58:45 pm »
Interesting  :-))
« Reply #143 on: August 11, 2023, 07:34:13 pm »
He's not finished a boat to need to use one - oh - did I type that out aloud.
That fingers resting on the delete account button I guess  :}2 O0 {-)
Klunk
« Reply #144 on: August 13, 2023, 06:42:16 am »
Making a canal boat out of milk cartons.
https://www.lutonmodelboat.co.uk/Club-Magazines.html
full time penguin
« Reply #145 on: August 17, 2023, 01:49:08 pm »
I noticed Martin was very quiet in replying to this comment  {-)
« Reply #146 on: August 17, 2023, 04:52:52 pm »
I got a meter out just the other day, actually!
My Club500 at final stage and need to check quiescent current on dry load .... if you remember what that is!   :P
( "My Club500" = any time in the next 18 months! )
« Reply #147 on: August 18, 2023, 11:46:42 am »
Don't be bullied into early usage Martin, title of this post does include the word "Quick" but patience is a virtue, take your Time- - - - - - - - Would have put a yawn smiley here but there ain't one.
  Regards Ian.
« Reply #148 on: August 18, 2023, 12:53:41 pm »
Martin knows we only comment like that in jest
his shirts prove he has a sense of humour  %)
« Reply #149 on: August 18, 2023, 01:40:15 pm »
Pages: 1 2 3 4 5 [6]   Go Up
Page created in 0.165 seconds with 21 queries.
