Model Boat Mayhem - Forum
Author Topic: Robbe u-47  (Read 9755 times)
bbdave
Robbe u-47
« on: February 09, 2008, 01:26:08 PM »
Hi just got home with the kit i'll be posting the build on here,but won't be getting the sticky stuff out yet untill i've read the instructions till they're worn out. so there will be lots of questions and problems posted here with the pics. Let the games begin!! ;D
Stan
Re: Robbe u-47
« Reply #1 on: February 09, 2008, 01:46:58 PM »
Hi BB Dave. Glad you are happy with the kit  just going in the garage to get the fleet ready for Sunday  morning.If you  open up the warship section on mayhem  Look for Gambier Bay you should see some pictures of my carrier.  Hope to see you at Harrogate in May.
All the best
Stan
bbdave
Re: Robbe u-47
« Reply #2 on: February 11, 2008, 07:26:50 PM »
Ok on reading the instructions it seems a fair amount of the joints are done with cyno is this considered a good joint? as i assumed cyno to be very brittle and would eventualy fail.
Sub driver
Re: Robbe u-47
« Reply #3 on: February 12, 2008, 11:05:35 AM »
Hello Dave,
Regarding your question about cyano, just about all the internal " frame " joints are glued using cyano, and when "fixed" are solid, if you have to undo the joint you have to physically tear apart the plastic the joint is VERY strong.
Make sure that it is right first time or you will have probs trying to fix it if its not in the correct position.
Build the frame up DRY first to ensure all is correct AND NOT TWISTED. I have seen some where the internal frame has not been given the care attention that is required when building and it looks awful and sealing problems follow later.
When correct you can always go over with Stabilit Express to reinforce the joints if you wish. I would reccomend STABILIT EXPRESS for the rest of the build as ROBBE do , not a cheap glue but very durable and it will stick all the brass parts to the plastic too. O0
It does pong a bit so do it when "she" is out for the day unless you have a centrally heated workshop / shed that is  {-)
If you are going for the Engel tank dive system you need to mod the internal frame / tray from the start to allow for the tank and reinforce it at certain points, just ask and I will give you some info and pics ( if you want that is ).
Also the screw joint needs SILVER soldering too, there is a lot of stress put on this one piece of the kit and I have seen / heard of this snapping when screwed in on some boats when soft soldered as it tells you too in the instructions and its a hell of a job to get it out again when half of it is stuck in the boat !!!!! >:(
Hope this is of use. regards sub
bbdave
Re: Robbe u-47
« Reply #4 on: February 12, 2008, 07:03:02 PM »
Thanks sub driver i've started to cut out the hull mouldings can you tell me how best to remove the parts from the flat sheet material it seems very tough to cut.
 also the hull sections i have cut seem to have a slight curve to them and are fidley to marry up is that normal?
The centre keel re-enforcement strip is tapered at each end does the keel pinch at either end to meet up with it, i am asking this as the instructions don't mention it they just say lay it flat and glue it?
« Last Edit: February 12, 2008, 07:16:45 PM by bbdave »
Sub driver
Re: Robbe u-47
« Reply #5 on: February 12, 2008, 07:19:06 PM »
I take it you are on with the central tray, you can use a fret saw or band saw , it should be scored about 1/2 way through so you only really have to cut the solid bits and then you should be able to fold and snap out the part you require. O0
bbdave
Re: Robbe u-47
« Reply #6 on: February 14, 2008, 08:58:44 PM »
does anyone know what current draw the kit motors have?
Subculture
    • Dive-in to Model submarines
Re: Robbe u-47
« Reply #7 on: February 15, 2008, 12:57:46 PM »
Never put an ammeter on a set, but they are powerful motors, hence rather thirsty.
If you are fitting a ballast tank, then it's worth looking at less powerful motors- the power is needed for a dynamic diver to get sufficient speed to produce the required downforce on the hydrovanes to submerge.
Also worth considering 12 volt electrics if you upgrade the motor.
6705russell
Re: Robbe u-47
« Reply #8 on: February 15, 2008, 07:58:43 PM »
I to am building the U47, i will get the motors out later and put the clip on ammeter on them.
What voltage are you intending to run at?
Russ
mick
Re: Robbe u-47
« Reply #9 on: February 15, 2008, 08:15:14 PM »
hello bbdave, be careful when using cynao, these glues can present breathing problems. The u-47 uses plenty of this type of adhesive. I use a face mask when building models with this glue....Mick
6705russell
Re: Robbe u-47
« Reply #10 on: February 15, 2008, 08:29:37 PM »
Ok i just tested the motors on the bench and they pulled 0.3amps running on 6 volt and 0.9 amps running on 12 volt, i couldnt stall them completely but very close and they were pulling 8.5 - 11 amps respec
Russ
bbdave
Re: Robbe u-47
« Reply #11 on: February 16, 2008, 04:59:17 PM »
cheers russ handy to know i think i'll stick to 6v as i'm not wanting to run fast
   i have seperated the hull parts and they don't marry up to well is that normal? is it just a case of tack gluing them together first then putting the re-enforcing strips in then filling any gaps later?
« Last Edit: February 16, 2008, 05:01:56 PM by bbdave »
6705russell
Re: Robbe u-47
« Reply #12 on: February 16, 2008, 07:11:04 PM »
I bought my kit second hand and to be honest the hull parts were cut out but not very good, i have sanded but i dont think you can get them spot on, however the centre hull section and the front hull section can be filled and sanded to achieve a good finish, with the rear section that needs to be quite flush because we cannot fill this gap, i am finding now that there is a few pieces missing but i can make most from scratch.
Russ
bbdave
Re: Robbe u-47
« Reply #13 on: February 20, 2008, 11:43:15 PM »
I have noticed in the kit the wotsits (can't remember the name) that hold the square  :-\ rod into the hydroplanes apear to be mild steel if this is the case are stainless or brass ones readily available if so where from?
Collets!
colin-stevens
Re: Robbe u-47
« Reply #14 on: February 21, 2008, 11:20:55 AM »
just about any model shop. Just ask for ones for youre I/Dia
grumpy old XXX
periscope
Re: Robbe u-47
« Reply #15 on: February 22, 2008, 07:21:23 PM »
Built my sub using Cyno two years ago - still going strong with no failures (famous last words)
The best cure for sea-sickness is to sit under a tree.
bbdave
Re: Robbe u-47
« Reply #16 on: February 22, 2008, 10:48:15 PM »
Tried a test today with cyno might just be me but i'm not happy with it so i think i'll use stabliit i have more confidence in it . i'm just not a cyno fan i'm affraid ???
bbdave
Re: Robbe u-47
« Reply #17 on: February 26, 2008, 07:39:41 PM »
All the bits have arrived today so the build can start. after many hours of reading and looking on the web i have decided to copy a method i have seen for constructing a new tech rack whih i think will be easyier than modifying the orriginal with this in mind i have bought a bayonet ring for wtc.
Dream arts tower deck and bayonett ring.
Engel tank with proportional control. and the centre sections cut ready for the masks.
I have some 4mm acrylic to make the tech rack i am copying this chaps idea which looks straight forward enough as long as i take my time. What could possibly go wrong???? :-\
http://media.putfile.com/u47-static-conversion
bbdave
Re: Robbe u-47
« Reply #18 on: February 27, 2008, 07:15:53 PM »
Glueing started this evening i have glued the slot masks on and i am now waiting for the glue to set on the joint for the centre section hull so far so good. i am glad i opted for the stabilit aproach as i have time to line every thing up.
bbdave
Re: Robbe u-47
« Reply #19 on: March 19, 2008, 12:06:34 AM »
i have got a little further i have got all the hull halves together now and have installed the tube in the centre section i decided to fit the planes and rudders after the hulls are glued together as i think it'll be easier to line everything up. i have built the first section of the tech rack which took alot of measuring but it seems to fit. the rest of the rack should hopfully be straight forward as it is jus a case of positioning the bulkheads where needed to accomodate all the gear. then comes the job of arranging the glueing order of the stern section end cap tech rack and bayonet ring  :D but i'm sure it will all become clear.
Hull halves stuck together
The first part of the bayonet ring attached using stabilit then epoxy and glass mat.
The motor bulkhead servo tray and endcap bulkhead ready for the rest of the tech rack.
if anyone spots any problems please let me know as this is quite a steep learning curve  ;D
« Last Edit: March 19, 2008, 12:23:16 AM by bbdave »
bbdave
Re: Robbe u-47
« Reply #20 on: March 19, 2008, 07:10:21 PM »
I have done some more work on the tech rack which seems to be ok so far there looks to be plenty of room but i'm sure that'll dissapear when all the gubbins comes.
bbdave
Re: Robbe u-47
« Reply #21 on: March 24, 2008, 12:49:25 AM »
for some reason all my pictures have gone off photobucket but i have them back now so i'll post the last few on here as a recap.
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: Robbe u-47
« Reply #22 on: March 24, 2008, 09:30:41 PM »
Nice work on the rack  :)
bbdave
Re: Robbe u-47
« Reply #23 on: March 27, 2008, 07:06:21 PM »
Been busy the past couple of days i've completed the rear section which was the most complicated part in my mind but it has all glued up fine so hopefully it should be fairly straight forward from here.
The rear a Aframes glued after being carefully lined up an measured to many times to mention
The bayonet ring fixed to the rack
The rear section being glued to the rear of the rack a nervous moment hoping all the lining up and measuring has paid off
Hey presto! i love it when a plan comes together.
Time for a celebratory cup of tea
bbdave
Re: Robbe u-47
« Reply #24 on: April 05, 2008, 12:21:30 PM »
Yesterday i made all the linkages to the rudders and rear planes sealed up the shafts etc ready for the bath later today so fingers crossed there will be no leaks  :'(. if all goes well i'll be then ready to glue the bow on and concetrate on the bow planes. So a few pictures of the install which doesn't look pretty but it is a very small space to work in so most of it is done using long nosed pliers which adds to the problem :D
bbdave
Re: Robbe u-47
« Reply #25 on: April 06, 2008, 05:23:40 PM »
Hi yesterday evening i  had a test in the bath and found a small leak around one of the propshafts which was quickly re-sealed then another duncking this morning which was leak free i blew into the valve to preasurise the cylinder until i couldn't get any more air in the only air that came out was around the prop tubes which arn't greased yet so that will cure that so all watertight which is better than i expected  O0.
 I started to make a watertight box for the bow servo which will be sealed with copious amounts of sealant and fitted into the bow when it's fitted.
 Just finished glueing the bow section on she's starting to look like a type vii now need all my batteries cable etc. to arrive so i can wire her up and go scare the pond life before filling all the joints and then  the real fun starts decking her and painting  {-)
Bath test
Watertight bow plane servo
The bow section attached
« Last Edit: April 06, 2008, 05:25:49 PM by bbdave »
bbdave
Re: Robbe u-47
« Reply #26 on: April 11, 2008, 10:34:21 PM »
Well all the electrical bits were got today and this evening i set about them with soldering iron and crimpers and after a couple of hours  it looked like a spiders web but with batteries connected it all seems to work i just need to tidy it all up a bit  ::).
All the bits
plenty to go wrong! but hopefully not
bbdave
Re: Robbe u-47
« Reply #27 on: April 18, 2008, 07:10:18 PM »
I have now completed the bow planes servo i tested it in a bowl of water and it seems watertight O0 i fitted it in the bow using plenty of silicone so that cross fingers is the last of the running gear.
 Started the tower which for me is very fiddley but alot of the small parts i'm going to leave off i think they won't survive model life the ones i've fitted i'm dubious about but nothing i can't fix when they get knocked off. I'm not very impressed with Dream-arts tower it has needed alot of work to get to line up correctly the mouldings married up eventualy but were still off centre and the vertical lines are way off true! they didn't supply enough wire to finish the job but none of these problems arise till i started building it at which point it's to late to send back. Maybe i should have gone for the Acurate armour option even though it's 1/35 i'm surwe no one would have noticed.
Notice the solder join on the short wire length!
the very small gun which is proving a struggle
Re: Robbe u-47
« Reply #28 on: April 18, 2008, 07:59:38 PM »
Impressive!  O0
What did you use to glue the perspex together for the bow servo?
Martin
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
bbdave
Re: Robbe u-47
« Reply #29 on: April 18, 2008, 08:54:30 PM »
Thanks Martin i initialy used waterproof cyno then i went over all the joints with plenty of silicone it's not pretty but should keep the water out. hopefully she might be ready for the mayhem weekend ::)
  probably not a question for here but i've found that now the servo is in place it chatters in use but it worked fine before being stuck in what could the reasons be non of the other servos are doing it just the bow.
Tug---Kenny
Re: Robbe u-47
« Reply #30 on: April 18, 2008, 09:05:40 PM »
To test if the servo or leads are faulty, have you tried plugging in another servo to that channel ?
Ken
Re: Robbe u-47
« Reply #31 on: April 18, 2008, 10:16:29 PM »
Test it for a few minutes every day as it may me that horrible vapour that silicon sealant gives off, it sometimes dirties up the contacts, in particular the position sensor potentiometer inside the servo. A few 'end to ends' should clean it up.
bbdave
Re: Robbe u-47
« Reply #32 on: April 18, 2008, 11:09:21 PM »
Cheers Martin i never knew it did that! every day is a day at school
sheerline
Re: Robbe u-47
« Reply #33 on: April 19, 2008, 09:22:50 AM »
Silicone bath sealant is air curing and contains formic acid, hence the acidic odour, this stuff can be very corrosive and may affect electronics under certain conditions.
bbdave
Re: Robbe u-47
« Reply #34 on: April 21, 2008, 05:58:31 PM »
I've been operating the servo now each day and it has improved a greatly so that was obviously the problem O0
