Model Boat Mayhem - Forum
Author Topic: Kyosho Jet stream 800  (Read 2091 times)
7563gn
« on: February 10, 2008, 12:49:03 AM »
Cananyone tell me what size electric motor  was used in the Kyosho Jet Stream 800 ? Thanks
john54
Re: Kyosho Jet stream 800
« Reply #1 on: February 10, 2008, 07:08:49 AM »
Hi And Welcome.
Have just converted a 800s i.c to leccy useing a 700bb turbo (no gearbox) running on 14 cells.
Not tryed her yet first run this morning (sunday)
Will let you know the outcome (maybe some pics)
bugsier65
« Reply #2 on: February 10, 2008, 11:36:02 AM »
hi i have one of these and it is fitted with a le-mans 360st race motor.this was standard fitting from new cheers chris
john54
« Reply #3 on: February 10, 2008, 01:11:09 PM »
Hi
Very happy with her had to try diffrent props s 30 was the best  :)
20min ish on 3000 paks  O0
Also a lot of success with my Manta (brushless) now on 16 cells went like stink :)
Sorry about the poor quality pics (phone/cam) :(
explorer750
« Reply #4 on: February 10, 2008, 01:54:06 PM »
Do you have any pics of this? O0
7563gn
« Reply #5 on: February 10, 2008, 02:12:48 PM »
Thanks everyone for the info if Im able to get this boat I will have to install a motor and a radio system this is kind of a rescue mission .I live in Canada and its 20F to day time to spend on the hobby.
john54
« Reply #6 on: February 10, 2008, 02:25:28 PM »
No pics of the manta running had to get someone on the t.x for me to take cr*p pics of the jet stream & they nearly stuffed that !
So g*d knows what might of happened with the manta :-\  nearly twice as quick.
explorer750
« Reply #7 on: February 10, 2008, 06:55:28 PM »
What fuse are you running with this set up as it is nearly the same as my Shadow.
john54
« Reply #8 on: February 10, 2008, 07:49:40 PM »
40amp i think prop choice is the main thing (revs up amps down) motor still cool after 15 min flat out.
john54
« Reply #9 on: February 14, 2008, 05:48:15 PM »
Me again
Going to take the motor and e.s.c (brushless 3000kv 60amp e.s.c on 19v ) and try it in the jet stream.
I think it may work because the j/s is surfacedrive & lighter than the subdrive manta.
Any thoughts gents or just try it & see what happens.
p.s has anyone had dealings with a hydro rat hydroplane just got one @ a good price.
explorer750
« Reply #10 on: February 14, 2008, 06:05:24 PM »
That should fine as both the manta and jet stream are about the same size, should go like stink if it works as the stock motor in a electric jet stream is only a geared 550.
john54
« Reply #11 on: February 14, 2008, 06:48:42 PM »
She was 16 ic now straight drive not to bad on 700bb but i like experimenting  :)
Where would we all be without it O0
offshore1987
« Reply #12 on: February 14, 2008, 06:54:32 PM »
This is a intrestin thread, iv got one sat up in the loft, with no motor in her  O0 might have to get some bits for her :)
All the best
P.s im from Portsmouth too
john54
« Reply #13 on: February 14, 2008, 07:38:00 PM »
Will let you know how she goes. I do really love the hull shape :)
