Hi surabaya,
I bought an old plank on frame trawler which had the same problem.
I stripped out all the electrics motor etc, and then used twelve hour setting epoxy resin thinned down seventy five percent.
I cleaned the inside of the hull as well as possible, and poured the resin inside the hull. As it is so runny it filtered through into all the cracks, and I just wiped away the small amount that soaked through with a cloth soaked in meths. It has left the outer finish almost un marked. A few planks raised slightly, but this looks like most trawlers any way.
There is a ready mixed paint product available for doing this job on rotted timber on old window frames etc. but this is quite quick drying and would not soak in as well. I just went to check what it is called 'TECHNIFIL'
I can't believe what I just discovered as a result. This is an old tin and the label has virtually rotted away. on closer inspection, it is just a tin of cellulose thinners with a paper label stuck on, and obviously a small amount of I assume styrene or similar to give a structure when it dries.
PS just had a thought, If you do try this method, don't thin with paint type thinners as this will destroy your paint finish. I used meths, but on thinking back this was only luck not forward planning as I often thin with paint thinners.
