Author Topic: Tug Motors: What Tug do you have and what motor setup?  (Read 29757 times)
« on: April 28, 2008, 11:37:50 am »
OK lets see what's what.
What Tug do you have and what motor setup?:
1. Model?                    ( eg, Robbe Happy Hunter )
2. Motor(s) fitted?     ( eg. 2 x Robbe Navy 550 2:1 gearbox - Cortina heater motor - direct drive.)
3. Radio setup?          ( eg. 4 channel 40MHz,  2 x Action ESC's, Hunter rudderl mixer, Bow thruster )
funtimefrankie
Re: Tug Motors: What Tug do you have and what motor setup?
« Reply #1 on: April 28, 2008, 12:24:37 pm »
Mobile Marine Models "Canning"
Model Motors Direct Bueler (not sure what model cost about £20) drives a 4 blade  3inch prop.
Futaba 40mhz 4 ch Electonize 43X ESC separate votage reg for the radio, off 12 volt main battery.
3rd channel switches the lights on/off
funtimefrankie
« Reply #2 on: April 28, 2008, 12:31:21 pm »
Mobile Marine "Nangee"
two Model Motors Direct 777s driving Graupner Schottels 6 volt, 12amp drive battery
Futaba radio with Mtroniks 15 amp escs,
Separate 6v, 4amp battery for radio/servos.
Robbe Bow thruster...(not really needed).
portside II
  • tugs at rest
« Reply #3 on: April 28, 2008, 02:03:11 pm »
Mobile Marines "Brakengarth"
Single refrigeration motor driving 90mm 4 blade prop in steerable Kort
Bow thruster + 15amp esc
Hitec eclipse 7, 8 ch Rx, electronise 30amp esc
2 x 12v x 12ah gel battery's (ballast)
JJC turbo diesel sound
daz (opperator) O0
J.beazley
  • The building never ends
« Reply #4 on: April 28, 2008, 02:39:34 pm »
Graupner Pollux tug
Graupner multispeed 140 motor spinning a 30mm 3 blade prop
Run on a 6volt 4ah battery
Futaba skysport4 40meg radio with Mtroniks viper 15 amp ESC
Jay
djrobbo
« Reply #5 on: April 28, 2008, 03:09:38 pm »
             LESRO SUN XX1
             M.F.A 400 WITH 2;1 GEARBOX DRIVING 45 MM 4 BLADE PROP
             ELECTRONIZE ESC WITH 40 MGH RADIO ALL RUNNING FROM 6 VOLT.....4 AMPHOUR BATT
barryfoote
« Reply #6 on: April 28, 2008, 03:31:20 pm »
Mobile Marine Models    Lady T
2 mobile Marine T4 motors running 2, 45mm brass props.
Futaba 4 channel radio. One to operate both motors via FLJ's P94 twin esc's and mixer unit.
One to operate the rudder and two as yet undecided.
Barry
catengineman
« Reply #7 on: April 28, 2008, 03:52:55 pm »
1, Tito Neri
2, Main drives X 2 Graupner 700 turbo through ASD's
3, B/Thrust  Graupner (paddle type)
4, Futaba FX 18 40 MHz (12channels )  3x Mtronic ESC's,
5, 2X 12volt SLA (main drive + pumps) + 1X 6volt SLA rec, (B/Thrust, lights, winches, Radar's)
R,
ray123
  • shuswap tugboat
« Reply #8 on: April 28, 2008, 05:51:45 pm »
hi all          i have a canadian logging tug
                2x robbe 'navys'  (540 geared 5:1)
               2x 97mm prop's in 100mm nozzle's
                                 f14 radio
                    2x 12volt 7 amp &2x 6volt 4 amp jell cell batterys
                     12lbs pull (all this in a 28inch model)
                       working towing winch
regards ray
« Reply #9 on: April 28, 2008, 06:10:55 pm »
     Is this the Tug ray?
    Damn near pulled me in!
Tom Eccles
« Reply #10 on: April 28, 2008, 06:25:21 pm »
Mountfleet Models Cruiser Tug
Graupner 720BB motor swinging a 70mm prop
4 channel Futaba 40Mz Tx
ACTion ESC, Whistle, Steam engine simulator, 2xACTion d.b.s, mixer, amp and speaker. (currently waiting for FLJ to import the sound units from Canada -I have my name on one-)
Clegg
ray123
  • shuswap tugboat
« Reply #11 on: April 28, 2008, 06:41:01 pm »
hi martin yes thats the one!  (hopeing to get to mayhem weekend?)  regards ray
Marks Model Bits
  • No Mustang Mark
  • http://marksmodelbits.com/
    • Marks Model Bits
« Reply #12 on: April 28, 2008, 06:43:55 pm »
LVM Ltd   LV801 12 volt motor
Not alot else in it at the moment as I have just started building it!! {-) {-) :D :D
Mark.
I HAVE NOT FAILED, I HAVE FOUND 1000 WAYS THAT DON'T WORK.!!!!
« Reply #13 on: April 28, 2008, 08:09:25 pm »
Happy Hunter
Robbie std motor set as supplied
plastic props in Kort nozzles
Mtronics 20 amp speed controllers,Captain Barry(sorry FLJ) Mixer
Futaba F16
TID 164
Protech 720 Motor
3ins Prop shop brass prop
Electronise speed controller
Futaba F16 Radio Gear
Shannon Scale Hobbies Kit (being built)
Graupener 900bbturbo motors
Kort Nozzles x2 Brass prop shop props
All singing all dancing Action goodies
Futaba f16 radio gear
Welsh_Druid
« Reply #14 on: April 28, 2008, 08:42:42 pm »
Tyne Models  " Northsider"
One of the last of MMM's large 12 pole hi-torque motors.
Running on 18 volts swinging a 105 mm dia 4 blade prop. ( 1-12v + 1-6v  7 amphr lead acid batteries in series)
Electronize controller.
Robbe F14 TX.
Lights and hooter with a 4" speaker.  ACTion  switcher for lights and sound unit for hooter.
Don B.
Adam
« Reply #15 on: April 28, 2008, 09:37:19 pm »
Smit Kamara 1:50
2x Torque 900BB on a 1:1 belt drive
2x 4 blade 72mm Propshop screws in nozzles
2x bowthruster
1x sternthruster
Futaba FC16 with dual twinstick and two multi-switches
tolnedra
« Reply #16 on: April 29, 2008, 11:53:17 am »
Tyne Models "Alfred"
Robbe Power 1000, direct drive to 90mm Rivabo brass prop, in 100mm Robbe Kort nozzle.
12v 7.2 ah SLA battery, 2 x 6v 4 ah for ballast and lighting.
Danny
Weeds
« Reply #17 on: April 29, 2008, 10:34:58 pm »
1. DICKIE
2. Vac-U-Tow Towboat motor, direct drive
3. Aquacraft 15A ESC, one 2A NiMh battery.
http://www.modelboatmayhem.co.uk/My_models/My%20Boat%20Images/Dickie/Dickie%205a.jpg
http://www.vac-u-boat.com/Motor545.htm
Ghost in the shell
« Reply #18 on: April 30, 2008, 11:39:01 pm »
Graupner Southampton
Motors - Speed 200 x2 on gearbox units, 40mm 4-blade propellers
R136F Futaba Radio
Go Nuclear!  you'll love it
ianb
« Reply #19 on: May 04, 2008, 10:54:13 am »
Model Slipway "Aziz"
2 Graupner 720 BB Torque direct drive
2 Electronize 15A ESC + BEC
Graupner Bow Thruster
JJC Diesel sound (2) and horn
ACTion P92 and P93 which connect and tidy everything up
1 x 12V x 10Ah SLA
Radio - JR 9 Ch. on 40Mhz
Model Slipway "Al Khubar"
1 x 12V x 6.5Ah SLA
Ian
bigford
« Reply #20 on: May 04, 2008, 12:44:52 pm »
smit hunter (happy hunter)
standard robbe 2x 750  stock 60mm props
540  bow thruster
happy hunter
same as above but with a 380 stern thruster also
amsterdam will be getting a
american bosch 12v motor
 fitted with a scratch kort  and brass prop
smit rotterdam (1/50)
2 x american bosch motors
540 b.t. and 540 s.t.
as far as radio gear i want to go with specktrum
mtronics esc's
Stretch
« Reply #21 on: October 04, 2008, 04:17:26 am »
Scratch built 60+ inch long offshore tug 1/24 scale.
two graupner speed 900 bb torque motors linked to two graupner schottle drives ( need powerful servos to hold them still )
four 12 volt 7.5 amp batteries linked to give 15 amps to the motors. Controlled by two Proboat electronic speed controls.
model weights over 75lbs and cruises slightly faster than scale speed.
awvs
« Reply #22 on: October 04, 2008, 04:45:03 am »
Robbe Happy Hunter:
1.   Two EF76 II each with 3:1 gear box, ESC Robbe mini 400 with extra cooling fan
2.   7 channel Cirrus 900 XLC, 75 Mhz
3.    Speed, bow thruster, lights, sound (horn), crane up & down, crane left& right
Weeds
« Reply #23 on: October 04, 2008, 11:40:57 pm »
By patmat2350:
 Model Slipways Envoy
MFA Como 6:1 (500 size)
Robbe Rookie
Prop Shop 4 blader
ray123
  • shuswap tugboat
« Reply #24 on: October 05, 2008, 06:46:03 am »
hi all my                     ' gale wind '
                         twin robbe navys 3:3--1
                        2 astex speed controls
                       2 50mm steering kort nozzels & 50mm  4 blade prop shop props
                      f 14 radio
                                           also ive taken this tug  to the following events
              2002 bilbao (spain)  2006 (rotterdam)    2008   (vancouver) & seattle(usa)
Page created in 0.329 seconds with 22 queries.
