Author Topic: Drive needed for the radar  (Read 4920 times)
flybobby
« on: August 03, 2006, 02:57:00 pm »
My radar is installed but I lack the motor to make it move.  I have tried to modify an old servo (running on 1.5v which gives me the slow speed) but it is cumbersome and could prove to be unreliable! :o
 I have seen radar/scanner motors on ebay some time ago but there are none on there now, which is sods law!
Does anyone know anywhere I can find what I am looking for, or are there any tips out there on using/adapting any other motor to do the same job?
Any advice appreciated  :)
wombat
Re: Drive needed for the radar
« Reply #1 on: August 03, 2006, 03:02:50 pm »
How about the vibrate motor out of an old mobile phone - this should be fairly compact and easily hidden
Tim the Wombat
flybobby
« Reply #2 on: August 03, 2006, 03:06:32 pm »
That could be the answer, I have just eyed up the wifes mobile!  Anything can be sacrified for model boats  :D
HS93 (RIP)
  • I cannot spell , tough
« Reply #3 on: August 03, 2006, 04:19:28 pm »
This is the people who sell on e-bay and have small motors  Peter
http://www.fastcomponents.co.uk/
flybobby
« Reply #4 on: August 03, 2006, 05:14:10 pm »
That is fantastic, thankyou.  MOtor ordered so problem now solved  ;)
Where would I be without this forum  ::)
Seaspray
crazy yank
« Reply #6 on: August 04, 2006, 05:16:52 pm »
Most small motors run at aboout 3000 rpm.  Do you have a means of slowing it down?  If not,  I made up an inexpensive speed control for mine to drop the revs way below runspeed.  Personally, I used a motor from the tape winder on a cassette answering machine that I scabbed from the garbage, literally.
I just came across a tiny motor from a mustache trimmer that was supposed to run at 1.5 volts.  The whole motor is about 7/16 inch diameter and about 1/2 inch in length and again was garbage bound, were it not for quick fingers and an alert mind.  If you want the speed control diagram, email me at  [email protected]
Crazy Yank
flybobby
« Reply #7 on: August 04, 2006, 05:40:59 pm »
Crazy Yank
Thanks for your offer crazy yank, but i have purchases a motor with gear reduction for £7 delivered!  The set up puts out a radar perfect 15 rpm.  Thant'll do for me  ;)
would like to see your wiring diagram as a matter of intrest though
« Reply #8 on: August 04, 2006, 06:52:23 pm »
Just a line to say - there are sites on the web which supply items for the budding robot builder which contain small motors, recently i bought ten mobile phone vibrator motors, one problem with these is     1) is to remove the mass weight and 2) to connect them to a suitable shaft as the diameter is very very small oh and short, some form of belt / friction drive may work, but the friction needed to stop the motor is very little, generally the tape deck motors being offered on most sites are the best compromise.
phil
« Reply #9 on: November 02, 2006, 01:13:51 pm »
[quote
[/quote]
here is a picture of the motor complete with mass.
Anyone noticed that the banners are missing from the top of the site - or is it just my PC ?
« Reply #10 on: November 02, 2006, 02:01:14 pm »
They are on my PC
Richard :)
chromedome
« Reply #11 on: November 02, 2006, 02:35:33 pm »
what boat is it for please?
chromedome
« Reply #12 on: November 02, 2006, 04:44:46 pm »
It must be the spam killer on my pc removing the banners, just installed McAfee,  :-\  DickyD
Chromedome, this is a picture of the motors i mentioned earlier, motors from mobile phones, they are not very good for driving props etc, i think as they dont take much to stop, but might be good enough for driving radar etc providing they are made direct drive, i am going to try them on 1/72nd helicopters.
Glyn Cleaver
« Reply #13 on: November 02, 2006, 07:18:26 pm »
Hi, A standard Futaba 148 servo does the job on my Smit Nederland tug no problem. Hope that helps other builders.
Cheers Glyn ;D
« Reply #14 on: November 02, 2006, 08:31:08 pm »
It must have removed your photos too!! :-\ :-\
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #15 on: November 03, 2006, 10:24:56 am »
I found a shop via the net in Canberra that supplies small motors for radar units with a 3 inch shaft , and the shaft is 1/8 inch in dia, they turn at 16 tuns per minute, they are 1/2 inch in diameter and just less than an inch long, and power usage is not much worse than leds...
Roy
« Reply #16 on: November 03, 2006, 11:24:38 am »
flybobby got his motor 8 threads ago you can stop now Roy
Who nicked your sub? ::) ::)
portside II
  • tugs at rest
« Reply #17 on: November 04, 2006, 12:34:08 pm »
 was at Blackpool the other week at the model show and picked up a radar controller with motor and a few spare motors made by JJC (the controller).
the motors are extreemly small aprox10mm x10mm round and a 5mm shaft ,all the wire in the kit to get you turning . ;D
Page created in 0.033 seconds with 21 queries.
