Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 ... 33   Go Down
Author Topic: Name that plane  (Read 178790 times)
Re: Name that plane
« Reply #350 on: August 06, 2008, 12:11:28 pm »
This one?
Arrow5
Re: Name that plane
« Reply #351 on: August 06, 2008, 12:19:53 pm »
Civvy Sunderland... a Sandringham ?
..well can you land on this?
Re: Name that plane
« Reply #352 on: August 06, 2008, 12:44:58 pm »
That's close enough! Short S-25 Sunderland 5(AN)
Want another one?
Re: Name that plane
« Reply #353 on: August 06, 2008, 12:47:44 pm »
What happens next?
andyn
Re: Name that plane
« Reply #354 on: August 06, 2008, 04:51:43 pm »
What happens next is that it carries on and ploughs into a line of parked aeroplanes sending debris everywhere.
Arrow5
Re: Name that plane
« Reply #355 on: August 06, 2008, 05:29:39 pm »
I think the crash barrier trips the plane up and it ends up with the tail in the air,smashed props and the deck-hand on the right running for clean underwear :o
Re: Name that plane
« Reply #356 on: August 06, 2008, 06:49:33 pm »
AndyN has it!!!
How did it get past two crash barriers?!?!   Oops!
Re: Name that plane
« Reply #357 on: August 07, 2008, 12:19:00 pm »
OK, what happened here?
andyn
Re: Name that plane
« Reply #358 on: August 07, 2008, 12:57:50 pm »
I believe that was caused by stress, as the starlifters did have major wing stress problems, and was what they were eventually retired for.
Either that or something crashed / landed on it.
Re: Name that plane
« Reply #359 on: August 07, 2008, 01:02:47 pm »
Nope! Although stress expatiated the cause... a more basic error was involved.
sparky
Re: Name that plane
« Reply #360 on: August 07, 2008, 03:48:40 pm »
Pilot folded up the undercarriage?
Re: Name that plane
« Reply #361 on: August 07, 2008, 08:01:05 pm »
Nope.   A routine ground operation....
andyn
Re: Name that plane
« Reply #362 on: August 07, 2008, 09:33:39 pm »
The plane on the right hit it
Just noticed the other wing  O0
Re: Name that plane
« Reply #363 on: August 07, 2008, 10:31:11 pm »
Naaa..... 61-2778 (cn 300-6004) Tennessee ANG. Aircraft was fueled with the vents to the fuel tanks plugged.
The wing over pressured and blew out. Damage compounded by wing root corrosion.
http://www.airliners.net/photo/USA%20-%20Air%20Force/Lockheed%20C-141B%20Starlifter%20(L-300)/0209303/L/&width=1024&height=780&sok=&sort=&photo_nr=&prev_id=&next_id=
Re: Name that plane
« Reply #364 on: August 07, 2008, 10:32:35 pm »
You can post your one now Andy.  O0
Ghost in the shell
Re: Name that plane
« Reply #365 on: August 07, 2008, 11:14:45 pm »
looks like an expencive error!
Go Nuclear!  you'll love it
Ghost in the shell
Re: Name that plane
« Reply #366 on: August 07, 2008, 11:18:25 pm »
sparky, c141 has its landing gear located in sponsons on the fuselage, not folding into the wing
andyn
Re: Name that plane
« Reply #367 on: August 08, 2008, 08:25:47 pm »
Ok then Martin
Got a better one, what happened here?
Re: Name that plane
« Reply #368 on: August 08, 2008, 08:33:37 pm »
Don't challenge a bigger plane, with bigger props to the boarding gate?
chingdevil
Re: Name that plane
« Reply #369 on: August 08, 2008, 09:03:26 pm »
Another plane nearby was having a test done on it engines when it started to roll forward and did that. Mythbusters tried that a while back and yes it is true thats what happens when a rotating prop hits another plane.
Brian
Ghost in the shell
Re: Name that plane
« Reply #370 on: August 08, 2008, 09:31:33 pm »
that WAS also a piper cherokee.
whoops
andyn
Re: Name that plane
« Reply #371 on: August 09, 2008, 06:37:13 pm »
I'll accept Martin's, but as he's just had a go lets pass the baton to Brian {-)
chingdevil
Re: Name that plane
« Reply #372 on: August 10, 2008, 05:31:46 pm »
OK
What are these?
Brian
bobinnit
Re: Name that plane
« Reply #373 on: August 10, 2008, 06:40:55 pm »
Could it be the    Ilyushin IL-76TD.
chingdevil
Re: Name that plane
« Reply #374 on: August 10, 2008, 06:46:31 pm »
It certainly could, your go Bob
Brian
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 ... 33   Go Up
Page created in 0.145 seconds with 22 queries.
