Author Topic: Futaba 2.4GHz trouble  (Read 3417 times)
dan
« on: August 27, 2008, 08:50:41 pm »
hi guys,
today i have had my futaba 2.4GHz transmitter replaced an it now has the I sticker on the bottom, however when i try using the new transmitter with the receiver (that was used with the old transmitter) it does not receive the signal, the receiver is flashing green but this means the ID is unmatched. so i was wondering if anybody that has replace their 2.4GHz transmitter has experienced this and how can i sort it out?
any help would be greatly appreciated,
cheers,
Dan
wideawake
Re: Futaba 2.4GHz trouble
« Reply #1 on: August 27, 2008, 09:01:41 pm »
Hi Dan
I'm not familiar in detail with the Futaba kit.  I use Spektrum.  However if it says that the IDs don't match - does that mean you need to rebind (or whatever Futaba call the process) the RX to the new TX?
HTH
Guy
dan
« Reply #2 on: August 27, 2008, 09:05:08 pm »
hi guy,
im pritty sure thats what i have to do, however im not sure how to do this, and i can not find the ID set button anywhere and it does not give any information on where i can find it
cheers,
dan
andyn
« Reply #3 on: August 27, 2008, 09:13:01 pm »
You need to re-bind it.
Will work perfectly
dan
« Reply #4 on: August 27, 2008, 09:15:33 pm »
hi andy,
this is going to sound stupid, but how do i do this.
cheers, dan
gingyer
« Reply #5 on: August 27, 2008, 09:19:22 pm »
dan,
I had the same problem the button you are looking for on is
on the reciever. it is located between the 2 ariels on the side
it is very small!!
to do this turn on the transmiter and power up the reciever then press the button
you should have this in the instruction manuel if not let me know
wideawake
« Reply #6 on: August 27, 2008, 09:33:33 pm »
Hi Dan
I thought that must be the problem but not being familiar with the Futaba gear wasn't sure of the procedure.    As you probably realise, part of the secururity of the 2.4GHz systems is that the RX only responds to it's "bound" transmitter.   The fact that this was suspect was the reason for the withdrawal of some Futaba sets in the first place.   Most 2.4GHz gear has a similar requirement, bluetooth earpieces and mobile 'phones for instance.
BTW you probably also realise that it's possible to bind more than one RX t your TX so you can use it with several boats if you get a RX for each.
Guy
dan
« Reply #7 on: August 27, 2008, 10:09:55 pm »
thanks gingyer,that was the switch i was looking for but couldnt find, so thanks alot!
and thanks for the rapid responce guys.
and that was one of the main reasons i bought this set guy, so i could have the different settings for different models on the one controller.
cheers,
dan
« Reply #8 on: April 11, 2009, 04:13:05 pm »
dan,
it is very small!!
Thank you young sir I have been trying to bind this lovelly set with another reciever fro the last hour reading the ins book but to no avail till I came to Mayhem land should have gone there in the first place
Page created in 0.034 seconds with 22 queries.
