Author Topic: Robbe Jet ski  (Read 3098 times)
BlazingPenguin
Robbe Jet ski
« on: September 19, 2008, 04:43:08 pm »
Does anyone know how to set up the twin props properly on the Robbe jet ski?
They seem to clash with each other on normal running and will rip off a prop if you dare to try turning....any help appreciated. ::)
Tester
Re: Robbe Jet ski
« Reply #1 on: September 19, 2008, 05:51:23 pm »
Not a lot of help but mine is set up as per the build instructions and no problems at all.
BlazingPenguin
Re: Robbe Jet ski
« Reply #2 on: September 19, 2008, 07:16:30 pm »
Erh...I dont have the build instructions¬ :(
john54
Re: Robbe Jet ski
« Reply #3 on: September 19, 2008, 07:40:43 pm »
Heard of that snag before. Try less servo throw or decrease rate on t.x.
grasshopper
    • A1 Hobbies Ltd.
Re: Robbe Jet ski
« Reply #4 on: September 19, 2008, 08:09:33 pm »
That's the one with two 'outdrives' isn't it? - have you got a link missing between the two, they shouldn't strike each other unless the turn angle is too high or there's too much play in the hinge points.
BlazingPenguin
Re: Robbe Jet ski
« Reply #5 on: September 19, 2008, 08:14:15 pm »
The threaded link between both drives is there so its not that.
If I reduce the throw I would less a good bit of manouverability I think.
I would like to see what the setup booklet says....anyone willing to forward a scan???
Tester
Re: Robbe Jet ski
« Reply #6 on: September 19, 2008, 08:57:15 pm »
I'll did out the manual and scan the relevant pages, it'll be tomorrow if that's ok
Richard
BlazingPenguin
Re: Robbe Jet ski
« Reply #7 on: September 19, 2008, 09:12:25 pm »
That would be fantastic Tester!
Please dont put yourself out at all, whenever you get around to it will be fine. O0
Tester
Re: Robbe Jet ski
« Reply #8 on: September 20, 2008, 09:54:15 am »
Scanned the manual and email to your address in profile.
Attached is pic file of the propeller set up section
HTH
Richard
BlazingPenguin
Re: Robbe Jet ski
« Reply #9 on: September 20, 2008, 10:26:37 am »
Just read it Richard and the horizontal/vertical alignmeny method they suggest is what Ive done myself, I do notice the drives are rather more splayed than mine,I'll also try to limit servo throw a little.  O0
Tester
Re: Robbe Jet ski
« Reply #10 on: September 20, 2008, 10:29:26 am »
It might be worth checking the pushrod length between the two drives, should be 41mm tip to tip
BlazingPenguin
Re: Robbe Jet ski
« Reply #11 on: September 20, 2008, 11:00:20 am »
Tadaaaaaaaaaaaaaaaaaaa!  O0
Problem solved sir!
Sweet as a nut,nothing touches anything its not supposed to...anywhere.
Lets se what tomorrow and 9.6v brings shall we?  :D
