Author Topic: rivets  (Read 4545 times)
byfly
rivets
« on: September 22, 2008, 03:19:09 pm »
Could someone please give me some ideas about how to simulate rivet heads in an engine house roof on a tug that I'm building. I've tried the dry glue blobs (epoxy and white glue) but I find it difficult (impossible) to get the blob size identical each time. I thought about using round headed panel pins but cannot find a supply. Any ideas would be gratefully received
Re: rivets
« Reply #1 on: September 22, 2008, 04:19:41 pm »
KEMO
Re: rivets
« Reply #2 on: September 22, 2008, 04:45:43 pm »
Hiya,
      I do'nt know what scale you want but this site
      www.modellingtimbers.co.uk/4604/74734.html
       have brass rivets 0.5mm thick and 3.0mm long.
Keith.
boatmadman
Re: rivets
« Reply #3 on: September 22, 2008, 10:45:22 pm »
I have used superglue gel with success. I put the drop on the primer and when all dry paint over. You do need patience and a little practice to get it looking ok.
Ian
RickF
Re: rivets
« Reply #4 on: September 22, 2008, 11:18:24 pm »
I'm a firm supporter of the "Pounce wheel" method. Get yourself an old clock gear or the appropriate pitch, mark out a piece of card with the lines of rivets and off you go. Just run the wheel up the lines, turn it over, a quick coat of varnish and you've got yourself a riveted roof.
Rick
ian kennedy
Re: rivets
« Reply #5 on: September 23, 2008, 07:39:36 pm »
Byfly,
My own prefered method for simulating rivet heads is to use a syringe with a square cut needle and i use pva wood glue un-thinned
Dont worry if you make a hash of it as you can wipe them straight off with a damp cloth and try again!
It does take a bit of practiceand a steady hand but you can get very good consistant sized heads and once dry just over paint...job done
Ian
nhp651
Re: rivets
« Reply #6 on: September 23, 2008, 09:44:20 pm »
i have for a few years now used a fabric "paint" that i buy from a haberdashery/art and craft shop.
it is made to go onto fabrics to make high lighted areas and dries quickly and hard.
it is fed through a very thin nozzle and is attached to the article by capilliary attachment. it gives perfect uniform rivets every time. O0
White Ensign
  • Limits must be limited!
Re: rivets
« Reply #7 on: September 24, 2008, 07:33:08 am »
I`d second the pounce-wheel method, depending on which scale you are you can use the wheel which is in the sewing box of your wife. Works any good for me- if you want to take a look under my posting for the Sir Lancelot:
http://www.modelboatmayhem.co.uk/forum/index.php?topic=11157.0
Happy modeling,
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
truman06
Re: rivets
« Reply #8 on: June 30, 2011, 05:06:58 pm »
Would you use coloured glue?
Page created in 0.029 seconds with 22 queries.
